SFL G CLUB South Florida G35's + G37's
Ignition Coils
Old Nov 29, 2009 | 10:13 PM
CarlosM's Avatar
Ignition Coils
Anybody with an extra set of ignition coils?? My car is misfiring and upon checking for the trouble code I got "multiple cylinder misfire". This could be a series of things but I want to start with the coils.
Old Nov 30, 2009 | 06:17 PM
CarlosM's Avatar
Checked all coils and changed plugs. Coils were all good. After putting everything back the car had a slight miss, almost nothing. I then began checking for leaks and found the gromet under the intake tube to be cracked. I went and got a different gromet that worked, put everything back and thank God I'm back in action. Believe it or not, a vacuum leak in your intake can cause the multiple cilynder misfires. There are other possible causes such as injector problems etc...
Old Nov 30, 2009 | 10:38 PM
Drako's Avatar
Glad you solved that issue...
Old Nov 30, 2009 | 10:57 PM
CarlosM's Avatar
Thanks.. I glad it was just the leak. Coils go for 100 to 150 each..
Old Dec 1, 2009 | 06:04 PM
2slo2bfurious's Avatar
Yeah everything causes p300. I started ignoring that code along with 5 others a long time ago. Glad you figured it out, ign. coils are way over priced.
Old Dec 2, 2009 | 12:15 AM
CarlosM's Avatar
Guess what, the car continued w/ the problem. I went to Infiniti on Griffin Rd and was told that grounding could also cause it. Going back to the drawing boards...
Old Dec 2, 2009 | 01:12 AM
Have you tried cleaning the MAF? Sometimes that helps. The spray cleaner is like 4 or 5 bucks at Advanced Auto.
Old Dec 2, 2009 | 06:18 AM
CarlosM's Avatar
Thanks. I'll check that too. It's true what you said about P0300, many things can cause a misfire..
Old Dec 2, 2009 | 09:57 AM
GreenGoblin's Avatar
The goblin resurrection
It could be a million things my car has had a p0300 for at least 2 years, along with like 10 other codes
Old Dec 2, 2009 | 11:39 PM
CarlosM's Avatar
I got a new coil, cleaned the MAF and grounded the hell out of the car. We'll see what now.. Hopefully it will be ok for Saturday or Sunday ,,PBIR
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
Jeff469
Sep 25, 2015 09:28 AM
