California Speedway roll call!!! 10/27/07
My untuned mildly modded revup makes peak power @ 6400 and only loses 4 hp from 6400 to 7000 RPM. I find myself shifting into peak torque if I shift the previous gear at around 7100 RPM's.
I need a helmet now!
1st run - 13.85 @ 101.45mph, 60ft @ 2.205
2nd run - 13.875 @ 102.07mph, 60ft @ 2.170
I only put in 2 runs, we ended up leaving at 2:15ish. And to get to the 3rd run, I'd have to wait until maybe 4? since the race before mine, a car spilled mostly likely his oil at the staging line, so they were only using 4 lanes.. sucks but yea, like Vlad said, I'll also buy two tickets next time I go.
And I'll probably get there at 6 this time. if we would of gotten there 15 minutes before we did, we'd probably would of gotten into group #1.
I want to see what Philip ran on his 2nd run!
What group were you guys in and what time did you get there.
The times that you ran were they with the M3? If so what yr is it and good times by the way.
I will be there for the Dec 1st SL for sure.
Originally Posted by OCG35
14.2 - very nice Vlad! 2.1 60' at Fontana is extremely successful!!!
Did they have to multiple prep in the morning?... I didn’t read everything ion the above posts...
that's really odd... my car is gaining past 6500 (on dyno)...
Originally Posted by Klubbheads
that is weird. When i asked Shawn what would it take to make power to all the way to redline, he said cams only. No matter what u do the car is going to have that little drop at the end.
The trq tanked (but this was before the 2nd TS ECU w/HFC)... I usually try to shift around 6700 but it still goes a couple hundred RPM before it actually shifts.
For autos shifting as late as u can is the best bet, that is because RPM drop compared to close ratio 6mt is significant when u shift to the next gear. No matter if u lose or make power up top ur best bet is to shift as late as u can. I see how autos would benefit from raising the rev limiter but as i found out yesterday and proved it by getting better trap speed, 6mts dont. Keep in mind im only talking about non revup engines, im not sure how the hp and tq goes for revups.
However with the 3.7 FD, I've actually noticed it shift sooner... not sure why but it does. So I have to find the right sport all over... I tried at Irwindale but was paying attention to several new things going on with the car... haven’t been on 1/4 with the near gears yet
Vlad and I arrived at 6:15ish, if I remember correctly.
yup, I took the M3. It's an '06 with 6k miles on it. Itching on buying some N/A parts for it, but this time, I think I'll just wait and once I have a good amount saved I'll shoot for FI. we'll see, but for now, I'm quite happy with it. I need a helmet or like the lady at the timeslips booth said, just slow down a tiny bit. lol
the cutoff for needing a helmet or not is 13.9, so I barely need it..
Originally Posted by skaterbasist
Wow, congrats Wally. I'm assuming these times are with the G35 with street tires, right? The car has alot of potential.
the temps and track were pretty darn good (could of wished it was a lil cooler though), but not sure how the G would of done yesterday... It still needs new tires by the way lol I'll blame it on the tires for previous ****ty runs lol
