heat problem with pop charger??
hahahah yes everyone blows up. You will have heat soak issues when using an aftermarket intake that does not have a large plastic shroud/box around it. The pop charger heat shield is a joke and only probably reduces heat by 5-10 degrees. Ambient temperature is what robs the engine of power in the engine bay.
go with the stillen, I have an injen wish I went with stillen
