Shop to Fix TSB ?!
Old Mar 11, 2009 | 02:37 AM
jutn35's Avatar
G35 Coupe
Exclamation Shop to Fix TSB ?!
Im in need of a shop to fix my TSB ( AXLE CLICK) on my 03 G Coupe. Im hoping the price would be better than the stealership. And also be really close to Anaheim hills ?
Anyone know of one ?
oor ... If anyone can perform these directions, ( HAS TO KNOW ABOUT CARS) no half assing
DIRECTIONS
u can find molycote grease at a pepboys, autozone etc...
-take your wheels off (rear)
-pull out the cotter pins with needle nose pliers(1 on each side)
-take off the the big bolt in the middle of the rotor where your center cap would be when the wheel is on.(1 on each side)
-take off the 12 bolts on the inside of the axle where it meets up to the differential. (6 on each side) to make it easier when u have your car jacked up or on a lift leave it in neutral with the e-brake off so that u can spin the axle to be able to access all the bolts easier as u go along. just make sure your car isnt gonna fall on your head. then let the inside of the axle hang so u have clearance to slide it out.(the ends closest to the middle of the car)
-slide the axles out.(they come out going inward towards the middle of the car) u may need to tap it inward from the rotor side to free it up. use the end of a thick ratchet and tap it with a hammer. couple of taps should loosen it up.
- use the grease to lube the living **** out of the splines on the end of the axle that slide into the hub. dont be shy with it.
-slide the axles back in. u will not have to tap them back in now that they are lubed.
- put the 12 bolts back in
- big nuts go back on
- cotter pins go back in. i put new ones in when i did mine because they get a little mangled when u pull them out.
- wheels go back on and it wont click anymore.
- it clicks because there is no grease in the splines of the axles and they are rubbing on the splines in the hub.
If you can do this and DO have the Know hows, ILL PAY FOR LUNCH !!!!
Old Mar 11, 2009 | 04:18 AM
G37Rider92649's Avatar
Psssh Lunch ain't worth this, that's hustling us, assuming your assss probably would take someone to Mcdonalds or something too
Just bring the directions to a regular mechanic and he should know how to do it, it shouldn't be that hard for them.
Old Mar 11, 2009 | 05:07 AM
jutn35's Avatar
G35 Coupe
come on ! dont you wanna be a dollarmenuaire ?! haha naw i was thinking of a nice seafood restaurant, but its up to who ever fixes it.
Ill ask my work if they can do it, but they only know **** about American cars
Old Mar 11, 2009 | 03:04 PM
jutn35's Avatar
G35 Coupe
Bump
Old Mar 12, 2009 | 11:39 AM
Day177017's Avatar
I know the chief mechanic at Tustin Infiniti. He does side work. I have him do all the work on my car. I never go through the service dept unless it's a warranty issue. I can get you in touch with him if you like.
PM me your contact info if you're interested and i'll forward it on to him.
Old Mar 12, 2009 | 12:53 PM
jutn35's Avatar
G35 Coupe
PM sent ^
Old Apr 25, 2009 | 11:40 PM
G35Vt's Avatar
anyone have the link for that actual tsb so I can print it and bring it to the dealer?
Old Apr 26, 2009 | 05:28 PM
Day177017's Avatar
Any reputable dealership knows about it. If they tell you the axle click is normal, try another dealership.
Old Apr 26, 2009 | 11:33 PM
G35Vt's Avatar
Problem is I dont have a dealer around me, not even in the whole state. I have to go through a BMW/Porche/Honda dealer I have the extended warranty with, I can go to any dealer, but the maint guys over there are good, so if I bring in the actual TSB they should be able to do it. Still looking for a link if anyone knows where it is, all the ones I've found so far are dead.
Old Apr 27, 2009 | 01:11 PM
Day177017's Avatar
http://www.aboutautomobile.com/TSB/2...niti/G35+Sedan
#10 on the list:
10 TSB Number:05002 NHTSA Number:10017773 TSB Date:November 9, 2005 Date Added to File:November 29, 2005
Failing Component:
Power Train:Axle Assembly
Summary:
Clicking noise from rear axles.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Mhacker
Sep 12, 2015 07:35 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
NJ6MT
Sep 10, 2015 08:40 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
