looking for a throttle body
Old Apr 7, 2009 | 04:46 PM
05REV's Avatar
Hey guys I'm curious to know if anyone in socal has a throttle body from a g35 that I can get from them I wanna play around with it and see what I can do
Old Apr 7, 2009 | 06:54 PM
Law to the Rence's Avatar
^ try looking at a junkyard or shops that do nissans, they probably have parts lying around
Old Apr 7, 2009 | 09:01 PM
CandlestickPark's Avatar
ill Sedan
Just curious, what are you trying to do with the throttle body? It’s a very sensitive part that won't work if you screw around with it or even simply touch the butterfly mechanism.
I did a quick search on eBay and there were a bunch to choose from.
Old Apr 7, 2009 | 09:08 PM
05REV's Avatar
exactly why i want one to practice with i work in a machine shop so i need to get the all the measurments of the butterfly so i can attempt to make one and if im successful i will bore out my throttle body
Old Apr 7, 2009 | 09:48 PM
^ nice!
keep us updated with your work
Old Apr 7, 2009 | 10:45 PM
05REV's Avatar
its going to be an adventour idk how long it will take or how difficult the butterfly will be to make in a slightly bigger size to fit the bored out housing but i cant wait to see if everything works out good and theres no problems ill be able to do it for other people
Old Apr 8, 2009 | 12:38 AM
fluxcapacitor's Avatar
junk yrd ftw!
Old Apr 9, 2009 | 02:53 AM
bikinilust's Avatar
sounds like you are trying to replicate this product
https://g35driver.com/forums/engine-...ttle-body.html
Problem is, you will have idling issues. You will need to adjust your idle RPM.
What would be a better idea.... take a Stainless Steel thick gauge tube that is of the desired (bigger than oem) opening. Then make a box to hold the oem TB motor and sensors. Then incorporate the two together. Then you can make an appropiate TB butterfly. Should work exactly the same as the OEM TB but w/a bigger TB tube. Also, keep in mind, i believe the oem TB has a bigger inlet than outlet to produce a venturi effect.
Someone already made a Bored to the max OEM TB and used a Ford Lightning MAF sensor housing and some fat *** tube as an intake tube. He obviously got a greater mass of air coming into the intake manifold, but the bigger intake decreases the velocity of the moving air. Thus the MAF sensor believes that less air is coming in (because it hasnt been recalibrated to the bigger intake tubing). So the MAF sensor voltage will need to be lowered. Dont ask me how they did that, but i have a feeling a tuning shop can do it.
GL
Old Apr 9, 2009 | 02:55 AM
bikinilust's Avatar
I was going to do what you are planning on doing about a year ago, and bought a new TB. I never got around to it, so if you wanna put a new one on your car and **** with your old one, pm me. I'll sell you my new one.
_M
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
