HELP ~ door lock and windows
Old May 28, 2010 | 02:32 PM
andonni's Avatar
Exclamation HELP ~ door lock and windows
my door lock and windows are not working, where can i get fix good and good price?
thanks~
Old May 28, 2010 | 02:36 PM
andonni's Avatar
thanks~
I"M in socal
Old May 28, 2010 | 04:00 PM
juan350gt's Avatar
for your door lock needs hit up python josh he does it for $30 if you go to him and it takes just a few minutes grea job just got mines fixed last weekend if the new actuator he puts inn ever fails he will replace it for free hit him up he's in So cal torrance Area he also has a thread around here. named - Need your door locks fixed?
thanks~
Old May 28, 2010 | 11:41 PM
Choleaoum's Avatar
i vouch for josh
Old May 29, 2010 | 02:54 PM
pythonjosh's Avatar
I have an inexpensive solution to the door locks, and I can install a new window motor for ya.
Unless the window(s) just need to be reset, that's simple. But if it's not working sometimes, that's a sign of needing a new motor.
You can get new motors at Riverside Infiniti or on ebay (don't get a motor pulled out of an 03, it's just as much crap as yours are now).
I got both of mine from Riverside Infiniti.
There is also a trick to the windows if they sometimes stop working.
The trick is to open the door, pull or push the window button, and close the door with the button in the direction you want the window to go.
Sometimes it can take a couple tries to get it to cooperate.
Here's my thread about my door lock service:
https://g35driver.com/forums/souther...cks-fixed.html
Old May 29, 2010 | 03:07 PM
Frankieg35's Avatar
My passanger lock and window both are out right now.. I just got a universal door lock actuator off eBay for $5 bucks and has a lifetime warranty..
Old May 29, 2010 | 03:11 PM
pythonjosh's Avatar
Yea getting the actuator is cheap. It's custom making the bracket and mounting it that's all the work.
I keep a stock of these actuators on hand.
Old May 29, 2010 | 03:52 PM
VictoriousG's Avatar
Hey josh can I get your number just in case this happens to me Ive never changed it so I know it's bound to happen soon.
Old Jun 1, 2010 | 07:13 PM
pythonjosh's Avatar
Any updates Andonni? Haven't heard from ya.
Old Jun 2, 2010 | 01:40 PM
andonni's Avatar
Originally Posted by juan350gt
for your door lock needs hit up python josh he does it for $30 if you go to him and it takes just a few minutes grea job just got mines fixed last weekend if the new actuator he puts inn ever fails he will replace it for free hit him up he's in so cal torrance area he also has a thread around here. Named - need your door locks fixed?
thanks~
Old Jun 2, 2010 | 01:44 PM
andonni's Avatar
Yes~ where is your shop?
G35-R
Nov 7, 2015 01:21 PM
itgogitrev
Sep 23, 2015 07:08 PM
TNRocker
Sep 21, 2015 08:36 AM
Paragham
Sep 15, 2015 12:04 AM
douglas555
Sep 10, 2015 04:48 PM
