Flat Tire - equivilent replacement?
Old Oct 10, 2005 | 12:05 PM
g35_anonymous's Avatar
I was driving back from Street Image yesterday and about half way home (25 miles from the shop) I noticed that the steering wheel was cocked a few degrees to the right (allignment) and also on bumps my car would bounce left to right.
Before I could head to the right lane to exit and check out the problem; POP!!!!!!!
Tire blown and I had to ride on the rim for a bit to get on the shoulder. My rim is pretty torn up but I think it is still usable. It was my rear passenger tire that blew (245/40/19).
My question is: I priced the OEM tires at various places for ~$375 (give or take $25 for the Rotenza RE050A 245/40/19); Can anyone reccomend a cheaper option that will fit the stock 19" rims?
<--- 05' G35c
Thanks.
On the bright side, I got my Rogue Engineering short shifter installed and I love it.
Old Oct 11, 2005 | 03:32 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can still go with bridgestone tires. Look into the S0-3's or the RE750's. If you live near SD i work for firestone and i can get you a good deal on either one of these tires.
Old Oct 12, 2005 | 01:01 PM
1KDUBLR's Avatar
Is there a defect with rear passenger tires? Because my rear passenger tire keeps losing air pressure...
Old Oct 12, 2005 | 01:48 PM
Not a defect... you probably just have a nail in your tire that you cant see. Ive had tires come in with little safety pin sized nails and they leak. or you could just have a little pin hole leak, either way they're both slow leaks so it wont just go flat on you. Take it in and get a flat repair.
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bTanz
Oct 15, 2015 02:31 PM
CJay
Aug 1, 2015 03:57 AM
itschuckster
Jul 25, 2015 08:07 AM
