FS: SPC rear camber arms
Old Feb 18, 2012 | 04:01 PM
sdz33's Avatar
Sold... Please close/delete...Thanks!
Attached Thumbnails SPC rear camber arms-spc2.jpg   SPC rear camber arms-spc3.jpg   SPC rear camber arms-spc4.jpg
Old Feb 19, 2012 | 05:21 AM
BigVicG35's Avatar
How long did you have them on the car?
Old Feb 19, 2012 | 01:00 PM
sdz33's Avatar
Cheap way to fix that rear camber!!!
Old Feb 19, 2012 | 01:13 PM
YOUNG1TRAN's Avatar
Can u use ur oem toe bolt?
Old Feb 19, 2012 | 01:24 PM
BigVicG35's Avatar
^^ You can but you need aftermarket to dial in right.
Old Feb 19, 2012 | 10:01 PM
sdz33's Avatar
Yes, you can use your OEM toe bolt, but you won't be able to adjust the toe correctly...
From some stuff that I read, you can actually use your OEM bolt to adjust toe, but you have to still elongate the hole... I can't say for sure if this works or not, but if someone on here can confirm, please chime in...
I know some people here or on my350z have a template you can download...
Edit: This might be the right size template..
http://my350z.com/forum/attachments/...-bolt-temp.pdf
Old Feb 20, 2012 | 01:10 AM
muhtish's Avatar
how much are the toe bolts?
Old Feb 20, 2012 | 07:28 PM
sdz33's Avatar
There is several companies that sell them under different part numbers... I believe you can get them from Rockauto. com
Here is a quoate from JasonZ-YA on my350z:
^ Just to be a little more clear - and since i found option #2 to be cheaper i figured i would post this up!
OPTION 1:
www.rockauto.com
-Nissan/YEAR/350z/suspension/alignment kit/
ACDELCO Part # 45K18060
More Info {Rear #19136556}
ADJUST KIT,REAR CAMBER/CASTER -; +/- 3 DEGREE TOE / CAMBER
* Non-stock item--shipping delayed up to 5 business days
PRICE: $27.79
ALSO:
OPTION #2:
www.rockauto.com
-Nissan/YEAR/350z/STEERING/alignment CAMBERTOE kit/
RAYBESTOS Part # 6161060
More Info {Professional Grade}
Rear Suspension; Minus 3 Degree To Plus 3 Degree Toe / Camber (Only 3 Remaining)
PRICE: $21.99
PART NUMBERS ARE DIFFERENT, BUT DESCRIPTIONS ARE THE SAME! SO IF THE $21.99 ONE IS THE SAME, THEN THATS A NICE PRICE!
Any locals wanna get their camber in check?
Old Mar 14, 2012 | 06:55 PM
Xx AzN xX's Avatar
Are these still fs?
Old Mar 15, 2012 | 12:02 AM
jtierney78's Avatar
Damn, hate that I missed this because I need these so good and the price was amazing!
Old Mar 24, 2012 | 08:14 PM
b_nazty's Avatar
i'll take em on friday if you still have them
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
