FS: Air Cup Kit
Old Mar 17, 2013 | 09:48 PM
dmcelso's Avatar
Air Cup Kit
What I have here for sale is a brand new cup kit from Stance Solutions(UK) setup is for front of car; all components are brand new and the price is firm at $975 shipped plus paypal fees.Pretty much everything you need...just need some wire to make everything work. The cup needs to slip over a 20mm shaft so make sure your coilover is setup for this. If you have a smaller shaft then you need a reducing sleeve. Static now has reducing sleeves to fit your application.As for rears the same company now can do rear setup for a true coilover system, unlike before. Adam can also make custom sized cups for your rear setup if you need it as well. Turnaround time before was 1 week, I am not sure as of now. http://www.stance-solutions.co.uk/1
To complete this setup( if you want rears) it would cost you another $755- $815.So roughly 2 grand to run a simple front and rear cup setup.
If you just need reducing sleeves and o-rings for a 12//12.5/14/15/16mm shaft the cost is $60. So if you purchase what I have and your shaft isn't 20mm you'll need 60 more bucks to make it work on your app.
2 x Static+ modules
5m of 6mm airline
all 6mm metal push connects needed
1 x schrader (car) valve to pressurise
1 x pressure release valve
1 x gauge to monitor system pressureViair 380c pump with relay
2 gallon tank
paddle
pressure switch
fuse holder
3/8"nptx1/4"npt bushing
Old Mar 18, 2013 | 12:38 AM
dmcelso's Avatar
btw WTT for a set of coilovers
Old Mar 18, 2013 | 01:01 AM
JDM_Cain's Avatar
oh man! So tempting....where are you located BTW?
Old Mar 18, 2013 | 01:32 AM
dmcelso's Avatar
I'm located in Vegas...
Old Mar 18, 2013 | 04:56 AM
Shanes_G's Avatar
Does anyone know if this fits stance gr+ coilovers?
Old Mar 18, 2013 | 08:16 AM
serges's Avatar
Trade for a set of mdu coilovers plus cash?
Pm sent!!
Old Mar 18, 2013 | 08:50 AM
dmcelso's Avatar
^^^Adam has reducer sleeves now so it can fit smaller shafts
Old Mar 18, 2013 | 08:51 AM
2fly4em's Avatar
Originally Posted by AmateuRN
Only coils these fit are Function Form in 20mm
Its the same set I've run on and off for 2 years.
You had to be the bear of bad news!! Lmao
Old Mar 18, 2013 | 10:08 AM
dmcelso's Avatar
lol!!! shaft siiiiiize!!!!
btw I bought the setup because I saw yours. I am glad you coordinated with Adam...In waited awhile to reducers and rear setup. Now that he's able to do it, I ended up changing my mind.
Old Mar 18, 2013 | 10:20 AM
Shanes_G's Avatar
I might get this just need to get off work and do some research on the shaft size situation. Ill let you know
Old Mar 18, 2013 | 10:37 AM
dmcelso's Avatar
^^^copy that
Old Mar 18, 2013 | 12:05 PM
serges's Avatar
Still interested aswell... so this is a full kit for the front right?
