Richie Strut Bar Comeback w/ Updated Events
Old Nov 15, 2008 | 06:53 PM
  #136
richie's Avatar
That's the only difference between the polished ($200 shipped) the CF ($265 shipped).
Old Dec 16, 2008 | 03:08 AM
  #137
4drmadness's Avatar
the richie strut bar will fit with the blox 5/8 spacer right. do i need to modify anything?
Old Dec 18, 2008 | 10:42 AM
  #138
imjackiechan's Avatar
what about picked up? i live in la and i can pick up asap!
and will fit over 5/16 spacer or its probably adjustable.
let me know about the pickup thanks!
Old Dec 19, 2008 | 06:59 PM
  #139
anynoe know this guys number?
Old Jan 23, 2009 | 08:15 PM
  #140
pczavala's Avatar
Originally Posted by blAk mAx
im not sure if i should try to drill out this corner.. would the bar move when making turns? that or make the bar a little shorter
i had the same issue! and my car i got it brand new no prior damage, i manage to fit it but then it would hit on the hood liner so i removed it and i guess it clears ok.
when i press down on the hood when its closed i can feel were the bar is except at one point towards the middle of the hood there is no clearance its like a perfect fit,
Should be fine right???
Old Jan 23, 2009 | 09:24 PM
  #141
blAk mAx's Avatar
he told me to unscrew the nuts on top of the struts and you can push the brackets out a little more. That's what worked for me.
Old Jan 23, 2009 | 10:06 PM
  #142
pczavala's Avatar
yeah i ended up doing that and it fit, only issue i had was with the hood not fitting. just took off the hood liner and it everything seems ok? (still seems like it is touching but more along the lines of a perfect fit.. tomorrow im going to give another go at it. imma have my brother push down on it as i tighten the bar make sure it doesnt creep up as a i tighten it.
THANKS!!
Sepsis
Feb 12, 2020 02:05 PM
iewsemaj
Feb 7, 2006 12:29 PM
cupid
Feb 5, 2004 04:13 PM
