Hotchkis sway bars on $ale! Free $hipping!!
Old May 1, 2009 | 10:53 PM
Larry@Showtime's Avatar
Former Sponsor
Hey Guys, We have about 10 sets of these awesome sway bars from Hotchkis in stock. 03-08 350Z/03-07 G35 Sedan/03-07 G35 Coupe Sport Swaybars (Front does NOT fit the G35X)
Item can be purcashed on our site for $350 shipped and forum special price can be revealed by entering " sway " in the promo code section.
Link to our site: http://showtimeautosports.com/index.php?cat_id=109
Or call us to purchase: 860-721-1688
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with Hotchkis track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Bars now come with welded retaining rings.
Specs:
- Front 1 3/8" (35MM) Tubular (Bar Weight 13.5lbs) - 4 Position Adjustable
- Rear 15/16"(24mm) Tubular(bar weight 5.5lbs) - 3 Position Adjustable
350Z & 03- 05 G35 Front Bar Rates:
- Hole 1 = 1525 lbs/in (22% Stiffer than stock)
- Hole 2 = 1845 lbs/in (48% Stiffer than stock)
- Hole 3 = 2270 lbs/in (82% Stiffer than stock)
- Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front Bar Rates:
- Hole 1 = 1525 lbs/in (5% Softer than stock)
- Hole 2 = 1845 lbs/in (15% Stiffer than stock)
- Hole 3 = 2270 lbs/in (42% Stiffer than stock)
- Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear Bar Rates:
- Hole 1 = 520 lbs/in (80% Stiffer than stock)
- Hole 2 = 655 lbs/in (125% Stiffer than stock)
- Hole 3 = 840 lbs/in (185% Stiffer than stock)
Old May 3, 2009 | 02:18 PM
Former Sponsor
ttt
Old May 4, 2009 | 02:14 PM
Former Sponsor
bump
Old May 5, 2009 | 09:58 AM
Former Sponsor
ttt
Old May 7, 2009 | 12:54 PM
Former Sponsor
ttt
Old May 14, 2009 | 06:39 PM
Former Sponsor
bump
Old May 21, 2009 | 06:06 PM
SoFresHSoCleaN's Avatar
Sways for a 08 G35s Sedan shipped to 33611? Thanks!!
Old May 27, 2009 | 11:16 AM
Former Sponsor
All Pms Sent
Old May 29, 2009 | 04:33 PM
Former Sponsor
ttt
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Jeff T
Sep 30, 2015 02:00 PM
