Swift Springs *** Best in the Market ***
SWIFT SPORTSPRING 2003~2006 G35 Coupe - Clearance: $359 Shipped
Z33 Sport Spring $359 Shipped
Z33 Spec R Swift Sport Spring $359 Shipped!
G35 (V35)
- Drop 1.0 inch front / 0.6" Rear
- 280 lbs/inch Front | 314 lbs/inch Rear
350Z Version (Also Fit G35)
- Drop .8" front | 0.6" Rear
- 336 lbs/inch Front | 364 lbs/inch Rear
350Z Type R version (Also Fit G35 Coupe)
- Drop -1.2" Front | -1.0" Rear
- 291-420 lbs/inch Front | 280-460 Lbs / inch Rear
Swift made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1 Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
Please email us at sales@ravspeconline.com
Thank you.
