Upgrade Vortech Coupe-Progress Thread
Old May 27, 2007 | 02:13 AM
  #91
G Thizzle's Avatar
Daniel is right... we have to run it so it is recirculating instead of going into the FMU and straight out... i dont know why we did it like that in the first place but we are going to try to get it done tomorrow... Daniel send me that pic of the FMU installed in your car... thanks bro!
Old May 27, 2007 | 12:51 PM
  #92
priscilla ls1's Avatar
Well just let me know if you need a hand .
Old May 27, 2007 | 01:03 PM
  #93
G Thizzle's Avatar
give me a call when you get a sec mark...
Old May 27, 2007 | 01:47 PM
  #94
Hey am going to call you here in a sec. Also Sharif told me that he does not have a base map for a vortec but that you should use the turbonetics base one that is on the utec. That should be good enough for you to make it to H-town just don't get on it.
Old May 27, 2007 | 01:50 PM
  #95
FastDontLie's Avatar
...we dont need roads...
Hey drew you going up to the shop today?
Old May 27, 2007 | 01:53 PM
  #96
G Thizzle's Avatar
yeah probably in about an hour... give me a call homeboy!
Old May 29, 2007 | 10:46 AM
  #97
G Thizzle's Avatar
update... everything is in.... just got to put the plastics back on the car... We will be heading out to SGP tomorrow morning to get tuned... thanks to all that helped! Look forward to getting down and dirty again on Devons install... Ronnie dont be a wuss get that supercharger!
Old May 29, 2007 | 02:01 PM
  #98
G Thizzle's Avatar
So yeah... i guess Mark at SGP got into a surfing accident this weekend so he will not be able to Tune our cars until hopefully next week... depending on how is oral surgery goes... and noone else at SGP has the skills to do it so looks like we are going to have to wait... Hope he is ok...
Old May 29, 2007 | 02:13 PM
  #99
I guess just bad luck. Did you talk to tom? Was the accident really bad? I'm working on a map for ya'lls utec that will work great for getting you guys around.
Old May 29, 2007 | 02:24 PM
  #100
G Thizzle's Avatar
Dang Mark... i really appreciate it... hopefully my car wont run so rich... how complicated is it to create a new map? Also when do you think i can dl it to the utec? Thanks again mark
Old May 29, 2007 | 02:28 PM
  #101
I have to do it manualy, it is not that hard I just plug the utec to a PC or laptop go into the parimiters and change it save it and your good.
Old May 29, 2007 | 02:35 PM
  #102
G Thizzle's Avatar
so when can i give you the UTEC to get that map on it? Will it run better than what it is running now?
Old May 29, 2007 | 02:44 PM
  #103
It should run way better. Sharif told me that you guys are running of the base map. You see the utec piggybacks it self off the ecu and the utec right now is telling it what you got. And right now it is saying no boost and stock injectors. It is saying the same for daniels car also. All I need is a 9v battery cable or 9v battery. Also do ya'll have a DB9 Serial cable? I think I got one at home I have to check. If I can get these thing I can just copy and past new maps in ya'lls utec.
Old May 29, 2007 | 02:48 PM
  #104
You know what I might just have that type of USB cable so I might not need the DB9.
Old May 29, 2007 | 02:55 PM
  #105
G Thizzle's Avatar
sounds good mark... all we have with the utec is the data cable it came with and the 9v power supply... but im sure i can get the 9v battery... since you got the usb cable i guess we should be good to go... until the tune anyways... thanks alot mark....
