Upgrade Vortech Coupe-Progress Thread
Old May 29, 2007 | 03:07 PM
  #106
priscilla ls1's Avatar
Sure I have to run home and get it. But I will call you when I am on my way.
Old May 29, 2007 | 03:40 PM
  #107
G Thizzle's Avatar
Thanks bro...
Old May 30, 2007 | 01:12 AM
  #108
G Thizzle's Avatar
ok ok... so my car has basically been running like crap ever since the install... tonight it was running so lean that my cats were glowing becuz they were sooo damn hott... Mark configured some numbers on the UTEC but it still ran lean... so that basically means that my car wasnt getting enough fuel.... did some research so here it is....
when installing the fuel pump you have to drill a 7/64 hole in the fuel pressure regulator (which we did not do) this lets the orifice have the flow capacity needed for the bigger fuel pump... so as of right now my 255 is still pushing through like a stock pump... fuel < air = lean! LOL also someone on the boards stated that if you dont drill that hole in the FPR your Fuel pressure will be around 70 psi... which is what i am right now... soo maybe...just maybe... this could be the answer to my problem... we shall see tomorrow gents... tune in later today as the "supercharger install" returns!
http://turboneticsownersclub.com/tur...icsinstman.pdf
http://www.my350z.com/forum/showthre...ght=walbro+255
Old May 30, 2007 | 12:17 PM
  #109
I think that might be the answer we are looking for bro. I knew it had somthing to do with the fuel pressure. This should be an easy fix.
Old May 30, 2007 | 02:50 PM
  #110
Also need to check your FMU this time for sure.
Old May 30, 2007 | 04:07 PM
  #111
FastDontLie's Avatar
...we dont need roads...
^^^Thanks Mark for all the help, we'll do the pump and fmu today. We will get this thing running rich.
Old May 30, 2007 | 04:08 PM
  #112
Hey did yall ever drill out the FPR?
Old May 30, 2007 | 04:12 PM
  #113
Did ya'll ever install the FMU and inline fuel pump that vortech provides with their full kit? Because I think this might be a problem we might have to take it out if you did.Also did ya'll ever drill the siphone inlet to the bottom of the fuel assembly I think it looks yellow?
Old May 30, 2007 | 04:32 PM
  #114
We are going to drill out the In-tank fpr today, aux. pump was never installed (not needed). But what we will do is look into the routing to the fmu hose. And see if we can hook it up to the laptop and datalog. You going by Mark?
Old May 30, 2007 | 06:33 PM
  #115
G Thizzle's Avatar
Here are some pics fellas....
Old May 31, 2007 | 11:59 AM
  #116
Hey drew, how did the cat go?
Old May 31, 2007 | 01:32 PM
  #117
Dude the cat we took off on the drivers side looked like $hit.
Old May 31, 2007 | 02:51 PM
  #118
venommaxr33's Avatar
Must Go Faster!!
so is everything good to go now?
Old May 31, 2007 | 03:09 PM
  #119
Well Drews car is running rich now, So im pretty sure once that cat is replaced exhaust will start flowing better. And now its just waiting for a tune.
Old May 31, 2007 | 03:57 PM
  #120
G Thizzle's Avatar
LOL...no you inpatient woman... I am going to pull the cats off and go with Robs fast intentions test pipes... i think i fried both cats so time to take them beeeaches off!
