Camber Kit Install
Old Jan 6, 2009 | 04:00 AM
ATX350's Avatar
Question Camber Kit Install
Hey guys, so the rims/tires are coming in soon and I'd like to get the SPC camber kit installed. What shops can you recommend to install this since it requires drilling into the under carriage?
I don't want to end up like this guy in other words: http://my350z.com/forum/brakes-and-s...one-wrong.html
Old Jan 6, 2009 | 11:57 AM
FastDontLie's Avatar
...we dont need roads...
are you installing just the camber kit or the kit and the toe bolt?
Old Jan 6, 2009 | 06:05 PM
ATX350's Avatar
Its the full kit. Looks like Tony is going to help me out with it. I appriciate it.
Old Jan 6, 2009 | 08:18 PM
wnt1bd's Avatar
Yea we don't do shops for nothing except body work, we always just do it ourselves.
Old Jan 6, 2009 | 08:21 PM
ATX350's Avatar
Cool, thanks.
Old Jan 6, 2009 | 08:51 PM
Sick Z's Avatar
Team 210 VQ'Z
What it do Eric!
Old Jan 6, 2009 | 08:55 PM
ATX350's Avatar
Originally Posted by Sick Z
What it do Eric!
Ha your *** has been so f*ing busy I gave up :P
Old Jan 6, 2009 | 08:59 PM
Sick Z's Avatar
Team 210 VQ'Z
**** I know bro I am sorry. Once all this passes through, I will be around alot more.
Old Jan 6, 2009 | 09:01 PM
ATX350's Avatar
Hey no worries at all bro. Family first! Luckily your team has been more than helpful so its all good!
Old Jan 6, 2009 | 09:02 PM
simpson's Avatar
What there is no drilling at all for a rear camber kit. Also there is nothing wrong with that guys install. When the car was jacked up it takes a while for the springs to compress back down. Also your car will be lower in the back with alot of camber and when you take the camber out it will bring the car up some in the rear. Install is simple you could do it yourself. Have a buddy help adjust the camber while you watch till you get to the shop for the aline.
Old Jan 6, 2009 | 09:11 PM
ATX350's Avatar
@simpson
According to this you do have to drill:
http://my350z.com/forum/brakes-and-s...tallation.html
Installation:
A. Replace the lower control arm with the Camber Kit Arm. Use stock toe bolt here.
B. Remove the spring perch arm and reinstall with the Toe Bolt in the Kit. Use the template in the kit and a Dremel to drill out the hole. Make the hole only big enough so that the Toe Bolt BARELY turns 360. DO NOT MAKE THE HOLE TOO BIG OR THE TOE BOLT WILL MOVE EVEN AFTER TIGHTENING IT DOWN.
Old Jan 6, 2009 | 09:20 PM
simpson's Avatar
When i put mine in i did not cut anything. my car is at factory specs. Are you doing this on a 350 z maybe that is different than the G35
Old Jan 6, 2009 | 09:21 PM
ATX350's Avatar
Indeed, this is for my 06 Z. Hence the name :P
Old Jan 6, 2009 | 09:24 PM
simpson's Avatar
sorry i did not even think about it. I also used my factory bolt with the factory washer so maybe that is why i did not have to cut anything. Worked out fine for me. Best of luck and i wish you were close i would be happy to help
Old Jan 21, 2009 | 10:53 PM
SA Z-ster's Avatar
yeah if you use the different bolts you have to make the hole a bit bigger.
