TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Fuel Filler Hose Recall
Old Jul 14, 2006 | 04:07 PM
G.Ride's Avatar
Just had mine done today. It took less than 2 hours to do as well as get washed. Only problem... 1 dealer in the area and its 1:30 away.
Old Jul 19, 2006 | 02:07 PM
kenchan's Avatar
im kinda surprised they don't include an alignment with this since
they do remove a huge portion of your rear sus...
Old Oct 31, 2006 | 06:55 PM
tylersphile's Avatar
Fuel Filler Hose Recall Notice
Originally Posted by HomieG35
Guys, these are evaporative lines. No liquid fuel runs through them. It does take about 2 - 3 hours to do - it requires dropping the entire rearend of the car, pumpkin, springs, and all. Three hoses are replaced.
Actually there is a voluntary fuel recall for the FILLER HOSE, outlined in the following recall notice below;
http://infinitihelp.com/Ownership/Bu.../ITB06-006.htm
This effects vehicles with the following VINs:
G35 Coupe: JNKCV51E*3M200022 – 226707, JNKCV51E*4M300013 – 310126
G35 Sedan: JNKCV51E*3M000014 – 336214, JNKCV51E*4M100021 - 114488
Old Jan 5, 2007 | 11:24 PM
medoug's Avatar
I have a 2003 MT coupe. My gas tank always filled up full with no problem. Then on Nov. 29, 2006, I had the filler hose recall work done. Since then, I have tried to fill up at 3 different stations and the pump clicked out way too early (about 3/4 mark) at all of them. I did manage to get them full (I think?) by pulling the nozzle almost all of the way out and barely squeezing the pump handle, trickling in the gas. At one of the 3 stations I even overfilled, spilling out some gas, using this method. The biggest pain is standing there with a flashlight for 5+ minutes trying to get it full.
I think I will have to contact the dealer about this. Hopefully they can fix it in one attempt since I live 60 miles from the dealer. Has anyone else experienced this problem after having the filler hose recall done?
medoug.
Old Jan 5, 2007 | 11:54 PM
medoug's Avatar
Also, can anyone verify where the splash-back valve is located? Is it in one of the hoses that are replaced during the recall work? Or, is there anything in the procedure that can affect the proper operation of the valve?
Thanks,
medoug.
Old Jan 6, 2007 | 12:38 AM
Tonys-G's Avatar
I have a quick question, I have had this happen only once where I was pumping the gas and the pump kept cutting off half way through and would not continue to pump enless I used the method Medoug stated.
again this only happened once so my question is do I need this done, does it even apply to my car a 2005 ?
Old Jan 6, 2007 | 03:27 AM
glennp_1999's Avatar
Got mine done a few months back.
Old Jan 9, 2007 | 11:03 PM
JD_AND_DA_G_RIDE's Avatar
Question
Nope, but there should be no issues. Let the dealer be aware what you've got done to the car - only pertaining to the fuel system. But remember, the recall only has to do with EVAPORATIVE lines - not any lines that fuel actually flows through. My car is supecharged and they didn't say a word about it except that they liked it. The biggest worry you will have is if someone decides to take it for a joy ride I would stay at the dealer while they perform your recall.
Got a question for you guys on this...I got the recall done and since then I've had my VDC,BRAKE light and SLIP light all turn solid and only turning off the car will get rid of them. Is there a possibility they screwed aroun with something when they dropped the rear end due to the lines being replace? Also, now my fuel gauge won't go all the way up....which I already know the answer to.
Anyone has any ideas please let me know.
Thanks,
JD
Old Jan 15, 2007 | 07:52 PM
medoug's Avatar
Hey, JD and DA G Ride,
Did the fuel gage stop working properly only after the recall work was done? I'm just curious, because that's what has happened to me.
Also, I noticed that they failed to re-install both rear plastic covers which complete the back of the rear wheel wells. I KNOW they were there when I put my winter tires on in November.
Also, when I looked under the car I found a nut resting between a couple of small hoses. It really makes me wonder what else they forgot to reattach. I guess I'll be giving the dealership a call. It really s*cks that I'll have to travel 60 miles each way to have something fixed that was originally O.K. until they screwed it up.
medoug.
Old Jan 18, 2007 | 12:00 PM
medoug.
Well I had the problem before but it had been working perfectly prior to then; it's just too much coincidence. Don't you just love how the dealer always claism to be right although the techs screw things up.
Old Jan 18, 2007 | 06:16 PM
superdave0096's Avatar
i know the fuel filler hose recall is not the same as the "not being able to fill the gas tank" problem. but i too have the problem of not being able to fill my gas tank all the way AFTER getting the recall done for the fuel filler hose. i had no problems filling before.... just an amazing coincidence?
Old Jan 18, 2007 | 06:20 PM
and i know its not my gauge.... i will be on empty (i know, not good to run the tank down that low) but only be able to fill 13 gallons into my gas tank. i try to click the pump a couple more times... but the most i get is 13.5 gallons, a little gas spillage (i HATE that), AND the fuel gauge shows only 3/4 full! traded a potential future problem for an immediate problem with filling the car up with gas.
Old Feb 23, 2007 | 10:45 AM
  #30
saborz's Avatar
This thread relates.
https://g35driver.com/forums/g35-sedan-v35-2003-06/128532-fuel-filler-hose-recall-anyone-experience-consequences-after-fix.html
Dallsinghjr1
Sep 17, 2023 11:25 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
