TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
window motor failure
Old Sep 28, 2006 | 01:16 AM
imalazeeass's Avatar
so how many of you have gotten this fixed?
So far I've repaired my passenger side motor TWICE and my driver side window once. So i've replaced the window motors 3 times during my 2 year time with this car. Isn't that a bit ridiculous? For all I know, my driver side is going to fail next in the next couple of months. My 99 TL with over 100k miles on it has perfect working windows!! And it takes my dealer close to 2 hours to repair it each time. I hate this!
Old Sep 28, 2006 | 01:50 AM
Gpair's Avatar
I had my pass done last summer. Cant believe they go out like they do
Old Sep 28, 2006 | 01:53 AM
BlackOutG's Avatar
mine driver side happen today for the first time
but iafter like 5 hours it got fixd by its self
Old Sep 28, 2006 | 02:42 AM
It starts off like that, then it will just die Keep an eye on it.
Old Sep 28, 2006 | 02:49 AM
hai109's Avatar
Happens all the time bro...Acura...Honda...Etc...
Old Sep 28, 2006 | 12:53 PM
Mountian Pirate's Avatar
lost my pass. window regulator 2 weeks ago...15k miles...dealorship had it replace over the weekend.
Old Sep 28, 2006 | 02:15 PM
izmir41500's Avatar
G35driver Addict
replaced the driver side window motor on my 05 6mt 2 wks ago. worked fine for a yr
Old Sep 28, 2006 | 03:02 PM
vt_maverick's Avatar
Had my passenger window motor replaced about 6 months ago. Now the driver's side is beginning to act up. My 03 goes out of warranty in December, so I have a maintenance appointment scheduled for mid-November to get the last of the warranty/TSB work done. I'm waiting until then to change out the driver's motor. Hopefully I won't have to pay to have it fixed for another year or two at least.
Old Dec 13, 2006 | 06:49 AM
MisterG35Tee's Avatar
I have the same problem with my windows; however, the problem is intermitent and only happens once in a while. when I brought it into the dealer they said they wouldnt replace the motor since they couldnt duplicate the problem. what do i need to do to get them to replace the motor anyway. Im afraid these may go bad in the future and my warranty is about to expire.
Old Dec 15, 2006 | 02:33 PM
OvaYahead's Avatar
I had my passenger once replaced. It took me 3 visits before I could get it replaced. First they said it was the guides or drive or needed grease. I can't remember. I finally had the motor replaced after I couldn't wind up the window in the middle of a winter rainy season. I now have grease lines again, but given up on having that fixed. I'm just happy that my windows go up and down at the same time.
Old Jan 2, 2007 | 04:48 AM
TRUGRIDER's Avatar
I've got an 05 coupe and my drivers side is acting up as well. I'll have to push up on the button a couple of times before it will actually come up. Guess I should make an appointment......
Old Jan 2, 2007 | 08:56 AM
Kris79's Avatar
battle froggy
well mine are starting to act up... =(
Old Jan 2, 2007 | 09:49 AM
pdjafari's Avatar
hmm my passenger side window seems to make a bit more noise than normal and seems a tad bit slower. other than that and the small grease streaks, how do you guys know they are acting up?? I told the dealer and they tested them, but said until they go bad tehy cannot fix it....not sure what to do now...
Old Jan 3, 2007 | 01:54 AM
TRUGRIDER's Avatar
My driver's side doesn't want to come up using the automatic button once its been rolled down all the way. So I can either keep pushing the auto button until it finally works or just use the manual.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
