TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Noise in back when speeding up
Old May 31, 2008 | 08:37 PM
volcom_koda's Avatar
Originally Posted by bz06er
maybe check your sway bar links? also do any of you have after market suspension? did you use all the stock isolators?
I am new at this so give me a break if this is a stupid question.
How would your end links make noise?
Stock Isolators?
Edit: I got my alignment done today. I decided while i was underneath the car i would check the end links to see if they were broken. I felt the links on the side of the car that isn't making any noise and there was nothing visually wrong with them. Nothing visually wrong with the side either. I noticed that when you move the end links they are choppy feeling. basically there was no smooth operation when they were rotated while still bolted on. When i moved the end links around that was when the noise happened. So.... check your end links and move them around. Its most likely the problem.
Old Jun 2, 2008 | 09:01 PM
infam0usndn2nv's Avatar
hey my car is like when i press the gas i head a stretchy noise and when i let go of it then i hear it again....nd its gettin worst
Old Jul 21, 2008 | 05:39 PM
jrdemers's Avatar
Originally Posted by BigD
Just got the car back from the Infiniti dealer. Rattle is not fixed, they have to order a part. There are two different things that is can be and the most common is a part behind the rear seats that connects to the side pillar. The bolts that connect the two pieces come short from the factory and tend to come loose. Creating a metal on metal rattle. I will take the car back in next week for hopefully a final fix. I will post the results.
B
Any more information on this? Can you let us know what the part that is connected is referring to?
I have found that my rear endlinks are loose and make a clicking noise when I move the sway bar around - I am going to replace those, but I don't think that that is everything that is making noise - see my thread about noise from the roof.
https://g35driver.com/forums/interior-exterior/233124-argggh-rattle-squeak-driving-me-insane.html
Thanks,
Joe
Thanks,
Old Sep 24, 2008 | 05:10 PM
SB_FX35's Avatar
Any one have this metal clunking noise on a 2008 FX35? It sounds like it's coming from the rear seat area. Not all the time, but it's annoying.
Old Oct 18, 2008 | 07:36 AM
G-MENTED's Avatar
axle click!
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
apintojr
Jul 23, 2015 10:52 AM
cyrus32
Jul 18, 2015 06:22 PM
