TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Jan 4, 2013 | 08:58 PM
  #1861
JKL1031's Avatar
well not if the warranty includes powertrain, and they stick behind it, which is the hard part.
Old Mar 13, 2013 | 01:23 AM
  #1862
Monsterkx2fiddy's Avatar
Shoot. I'm in the market for a 05-07 in the 80-100k mile range. Now I'm reconsidering. I'm not going to put more oil in my car every week
Old Mar 13, 2013 | 09:41 AM
  #1863
wechslerl's Avatar
Just wait one more month until I find out if my last attempt to cut down oil consumption was successful.
Otherwise I have a 2006 Manual with 42,000 miles on it, that uses 2/3 of a quart per 1000. It remained like this since I first discovered it at 26,000. Did not get any worse.
I am now @ 450 miles after a deep cleaning. Need to check @ 1000.
Old Mar 13, 2013 | 10:08 AM
  #1864
youloze's Avatar
Originally Posted by Harv2ey
I can't imagine that they'd want to see all of your service records since you've owned the car,
I did not have to show any records when I was approved for my long block.
Old Mar 13, 2013 | 10:12 AM
  #1865
wechslerl's Avatar
This is my latest attempt, because I have tried everything else.
This time I have in the crank case 4 quarts oil used in diesel engines and 1/2 quart MMO.
The compression rings are all fine (compression is very good)only the oil rings have a problem.
I hope nothing is broken and the cleaning solution will free them all.
Old Mar 13, 2013 | 10:21 AM
  #1866
youloze's Avatar
For anyone that has had their engine replaced:
Have any of you experienced a very mild rattle on cold starts that only lasts about 2-3 minutes? I'm getting a very faint random sequence rattle when I start the car after sitting for a long period. Doesn't sound like a bearing, it's a more random rattle. It only happens after about 30-60 seconds from starting the car and will continue for about 2 to 3 minutes then go away.
I tried to pinpoint the sound from under the car using a screwdriver to the ear but I cant find where it's coming from but it definitely sounds internal (either engine or trans). Has anyone had this issue after receiving a new engine from Infiniti?
Old Mar 13, 2013 | 10:36 AM
  #1867
HereKittyKitty's Avatar
My engine has been re-built, non-Nissan warranty, no problems at all.
Old Mar 23, 2013 | 03:20 AM
  #1868
almost3flips's Avatar
To reduce oil consumption try not to engine brake or leave the car in vacuum at higher rpms. If you drive aggressively that will also add to the consumption. I did that a lot during my oil consumption test and in 3000 miles I took out 2 and a half quarts. I wanted to make sure I got a new short block from it.
Old Mar 23, 2013 | 10:39 AM
  #1869
Texasscout's Avatar
Mine has always rattled on start up until the Oil Pressure is up. About 1/2-1 second.
My 2011 Nissan Frontier with the 4.0L does the same only a bit shorter.
Old Mar 23, 2013 | 12:14 PM
  #1870
youloze's Avatar
Mine lasts about 2-3 minutes though, until the car begins to warm up.
Old Mar 24, 2013 | 12:12 AM
  #1871
Zioxx's Avatar
Youloze- How many miles did you have on the car when you got your block replaced?
Old Mar 24, 2013 | 12:45 AM
  #1872
youloze's Avatar
Somewhere around 67k
Old Apr 6, 2013 | 09:37 PM
  #1873
Kyle Barbaro's Avatar
Infiniti said I was down 6mm at my 1000 mark, is this normal or should I be worried? Infiniti said it was fine..
Old Apr 6, 2013 | 09:46 PM
  #1874
NGK's Avatar
NGK
Borderline. They could prob call it either way. Mine was 8-10 and they tried to push me out the door. I brought all pages of the tsb, and had to show them. Be vigilant, print it out. Bring it with you and ask
Old Apr 6, 2013 | 09:51 PM
  #1875
Im at 95k, just bought it a couple months ago off a dealer, nothing would be covered under warranty so I would have to keep adding oil.. am I about a quart low? im not sure about the math here
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
