Infiniti Rev-Up Oil Consumption TSB
Sep 25, 2009 | 12:48 PM
  #887
yeah, my dad ust changed the oil. So I told him to drive the car more than he has been, and to check it in 1000 miles to see where it sits. If it's good then I'll just keep an eye on it. If not then they'll record it. The guy at Infiniti faxed my mom the same pages of the TSB they use for testing and told her to have my dad follow those steps and we could check it ourselves.
Reply 0
Sep 28, 2009 | 09:00 AM
  #888
Got my new V2 installed last week, they also installed two new catalytic converters. So far it's working nicely, I have about 800 km's on it since Thursday and it is smoother, idles down to lower rpms and is a bit easier to pull away from a stop than it was before. I'll keep my eye on the oil consumption and see how it goes.
Reply 0
Sep 28, 2009 | 11:06 AM
  #889
I'm having new engine put in this week. Can anybody tell my what their experience has bee with the new engines. Thanx.
Reply 0
Oct 14, 2009 | 01:18 PM
  #891
Quick question for all those who have had the swap. Mine is in at the shop as we speak and the engine should be out by tomorrow. They were saying that its not a bad idea to put in a new clutch while they have everything apart since it will be just parts that I'm paying for. I have 32k on the vehicle. Has anyone else done this? Is it a good idea? What is the typical life span of the clutch? I do drive the car hard(like its meant to be driven). They said they would let me know what percentage is left on it and give me their best judgement. Wanted input from those who have gone through this. I unfortuneately live 6 hours away from the dealership and cant just drive there to look at it myself. Any help is great!
Mark
Reply 0
Oct 14, 2009 | 01:34 PM
  #892
Quote: Quick question for all those who have had the swap. Mine is in at the shop as we speak and the engine should be out by tomorrow. They were saying that its not a bad idea to put in a new clutch while they have everything apart since it will be just parts that I'm paying for. I have 32k on the vehicle. Has anyone else done this? Is it a good idea? What is the typical life span of the clutch? I do drive the car hard(like its meant to be driven). They said they would let me know what percentage is left on it and give me their best judgement. Wanted input from those who have gone through this. I unfortuneately live 6 hours away from the dealership and cant just drive there to look at it myself. Any help is great!
Mark
I had 29k miles when I got my V2 I had them check the clutch and it was about 50% worn, so I decided to just get it done, they won't charge you for any labor (which is a lot and $$$), just the parts. The choice was obvious for me.
Reply 0
Oct 14, 2009 | 02:06 PM
  #893
It might be worth it if your within 10-15 k of needed it. I think the labor for that at the dealer is about $ 700. You should consider an aftermarket clutch/flywheel upgrade at this time if appropriate. A lot of dealers will work with aftermarket performance parts, but you may have to go without a warranty on the non OEM parts. good luck.
Mark
Reply 0
Oct 15, 2009 | 10:43 AM
  #894
Go ahead and get the clutch done if its around 25% left. When I bought my G35 used with 34K on it, it already had a new clutch and V2 motor. The said the clutch was about done. I'd go aftermarket (Nismo or Stillen) and that may retain your warranty on the car. Personally I think the new OEM clutch is garbage. I have had the new clutch slip twice, either the tires are just that grippy or the OEM clutch is just that weak. I never had a clutch with less than 10K on it slip. I have the car totally shut down and go into limp mode in the middle of nowhere...thankfully I knew how to reset the ECU and after 3rd try, the car drove fine and all dash warning lights were gone. The next day the dealer could not
Overall, I loved my first 2003 6mt G35 sedan I owned. 45K miles of bliss, reliability, and the clutch and motor felt as fast and smoother than this 2007 G35 coupe with rev-up motor. I have had this G35 at the dealership about once a month since I have owned it for many different issues. They have fixed everything under warranty but I don't think I would risk owning this car after the CPO warranty expires. My dealership service experience has been terrible at Infiniti of Lake Norman. Infiniti has lost ANOTHER long term customer. This would be my 5th Infiniti and sadly my last.
Reply 0
Oct 16, 2009 | 12:05 AM
  #895
^ I would have to agree with you on the last statement. This is my first Infiniti and my last.
Reply 0
Oct 16, 2009 | 08:31 AM
  #896
this is my second nissan product...the first needed a new motor at 42k(03 sentra se-r)
on the other hand this car is probably consuming less oil then my celica gt-s or rsx-s so w/e..lol
Reply 0
Oct 17, 2009 | 03:47 PM
  #897
Here's a question. I was wanting to install a Vortec supercharger on my 06 G35. Now that I have had this engine swap performed, is it still the same Vortec that I purchase meaning is this still the same engine set up. I know they offer different superchargers based on if you are a rev-up motor or not. I would assume that since mine was a rev-up that I still would purchase the same one. Thanks for the input.
Mark
Reply 0
Oct 18, 2009 | 12:42 AM
  #898
^ If you originally had a revup, they'll replace with a revup. Check your paperwork from dealer. Should list part number as what's listed on TSB.
Reply 0
Oct 18, 2009 | 03:17 PM
  #899
Finally had my non-revup engine replaced about a month ago. Just drove my first 1,000 miles and the oil is down below the L. The dealer told me that I will burn some oil during the first 1k miles, but that is just ridiculous. It is barely better than before I had the engine replaced.
What are my chances of Infiniti/Nissan buying back my car? 5.5 years old. 54,300 miles. Already on my 2nd transmission, 2nd engine, 6th Bose radio, 5th set of tires due to tire feathering, 4th set of window motors, 3rd throttle body, 3rd MAF sensor. 3rd clutch (first 2 were not installed properly from Factory & Dealer).
Reply 0
Oct 18, 2009 | 03:21 PM
  #900
^Wow that is ridiculous. There should be a rule that if you replace something a certain amount of times, they have to buy your car back.
Reply 0
