TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Jan 19, 2010 | 11:31 PM
  #961
alfhasg35's Avatar
Originally Posted by spankey167
Yea! I went to Tustin to ask about my headlamp (mines an 03 with the defect of cracking due to the fog light). My car is still under warranty. Some lady said they would not cover it under warranty.
Does anybody know where I can go to get that replaced?
Thanks!
you have an 03... what kind of warranty do you have..?
Old Jan 20, 2010 | 04:40 PM
  #962
SxSkyLinexS's Avatar
^ a lifetime warranty
Old Jan 20, 2010 | 11:48 PM
  #963
SaintRedRocket's Avatar
Today was a splendid day.
Driving back from meetings in LA only to have my engine cease on me while driving in the left lane. Lost power steering, brakes, and engine function. Almost got rear-ended because it was like I hit a brick wall when the engine gave out. Let out the clutch and was able to make my way across 3 lanes of traffic on the 55 without getting hit and no brakes, power steering, or engine function.
Two tow trucks and 3 hours later, it was dropped off at the dealer. Dealer tried to tell me on the phone when I called that it was caused by water and I'd have to run it through insurance. They did a quick inspection when I got there and the engine & air intake were completely dry. The coolant reservoir was completely empty and the oil level was TBD due to being towed.
I'll find out tomorrow about the exact problems with the car, but I'm 99.9% sure that the 2nd engine failed with 3,007 miles on it due to oil consumption (again). The last read on the dip stick was 2 days ago: ~8-9MM from the end of the stick was all that was left.
Old Jan 20, 2010 | 11:51 PM
  #964
tragedycat's Avatar
Sorry to hear about your troubles, but second engine? Geez. I wonder what we're all going to do once these cars start falling out of powertrain warranty. That was a huge risk I decided to take in buying another G35 after my last one got wrecked. Hoping it doesn't come back and bite me in the butt.
Old Jan 21, 2010 | 01:12 AM
  #965
alfhasg35's Avatar
oh sheeyat..!! let us know what happens.. i have 400mi on my car since the motor swap.. i haven't checked the oil yet.. i will check it at 1000mi when i take it in for the first oil change..
Old Jan 21, 2010 | 01:22 AM
  #966
Jairen's Avatar
I went to Riverside Infiniti and initiated an OC test.
Looks like I'll be have trouble claiming an OC test, since they OVERFILLED my oil.
According to the dipstick, the oil level is about 8mm above the "H" line!
So, I'll have to burn at least 16mm in 1000 miles to get approved. Even If I burn 12mm in 1k miles, I'll be 4mm short for approval. SUCKS!
My engine usually burns 12mm in 1k-1.5k.
DAMN!
Old Jan 21, 2010 | 01:42 AM
  #967
alfhasg35's Avatar
i don't think u are suppose to touch it but... check this out.. i took it back after the first test, never touching the dipstick and it read FULL... and i was like.. awwww damn.. i don't have the OC problem... but then i thought.. hey... they didn't put a zip tie or anything to keep me from tampering.. how do i know if they OVERFILLED it or not.. so ... at 2000 miles i brought it back and it was low.. i was like.. welll.. cant be that low.. because it was full at the first test.. they said it was soooo low... that i needed a new motor.. no third test... ur not suppose to touch the dipstick or anything or else you can void the OC test...could be a way they do it...overfill ... then check at 1000... then check at 2000...
Old Jan 21, 2010 | 01:43 AM
  #968
u shoulda checked it hwen u left.
either tell them that next time or do 8k revvs
Old Jan 21, 2010 | 01:45 AM
  #969
alfhasg35's Avatar
so... if they overfilled mine...let's say by 8mm... it burned 8mm in 1000mi.. i don't think they will FVCK u... they are legit...
Old Jan 21, 2010 | 01:46 AM
  #970
alfhasg35's Avatar
that's what i was thinkin... i should have checked it before i left.. but.. i have a new motor now and they are legit... 400mi and counting..
Old Jan 21, 2010 | 01:53 AM
  #971
^ riverside infiniti's pretty cool :d
i talked to mike a while back
Old Jan 21, 2010 | 01:56 AM
  #972
alfhasg35's Avatar
Tony is way legit and i asked him which service advisor he would prefer and he referred Jeremy Scheetz... Both those guys are LEGIT....thinkin about buying another infiniti just cuz of them... or a lexus isf.. one of my best friends is an SA there..
Old Jan 21, 2010 | 11:49 AM
  #973
V35 Skyline GT's Avatar
6MT Coupe
Over-filling IS one of the oldest tricks in Dealers book for this issue and then to be told and officially documented your VQ is fine when you come back. Another old common trick: They top you off when you return, THEN take official test reading after sitting per TSB = no issue...goodbye.
Watch your G like a hawk. Don't let it out of your sight. Funny how I qualified after keeping my G in sight after being played twice with what I just mentioned above. I requested test to continue, per TSB saying I had that option.
Dealers are dealers, no matter how nice they are. Be respectful and nice back, but don't trust them as far as you can throw them. Their head master mechanic is who played me, not the SA or the SM to my knowledge. But they all are in the same think tank during meetings, so who knows.....
Old Jan 21, 2010 | 12:35 PM
  #974
alfhasg35's Avatar
I say hit up tony and let him know what u discovered.. see what he says..
Old Jan 21, 2010 | 03:11 PM
  #975
6MT Coupe
And request test to start over to be fair and accurate this time to owner.
There's never ever a legit reason to over-fill an engine in any situation period.
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
