TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
*OIL CONSUMPTION TSB has been updated by Nissan*
Old Aug 21, 2010 | 02:05 AM
TIAN's Avatar
Hold The Line
If I'm out of warranty is the OC test honored? 05 here
Old Aug 21, 2010 | 11:58 AM
jookyshank's Avatar
I haz hugz to givez
How many miles on the car Tian?
Old Aug 21, 2010 | 12:07 PM
dukehotty's Avatar
Is the oil consumption problem JUST with manual transmission G35's? I have an 06 5AT with 47K miles. Should I take it in?
Old Aug 21, 2010 | 01:05 PM
TIAN's Avatar
Hold The Line
61k
Old Aug 21, 2010 | 08:17 PM
spinna001's Avatar
Originally Posted by Tian
61k
You should still be good bro. Powertrain warranty is 70,000 miles and 6 years
Old Aug 23, 2010 | 12:24 AM
Jee_35's Avatar
anyone with mods have any luck with this tsb?
Thanks!
Old Aug 24, 2010 | 10:10 PM
wariospeed's Avatar
I just bought an 04' 5at awd sedan and was wondering if i should go get the OC test???? what do you guys think.....since i traded in my DC5 for the G.. thanks guys hope to hear from ya ...
Old Aug 27, 2010 | 06:45 PM
jookyshank's Avatar
I haz hugz to givez
Pretty sure this just pertains to '05-'06 6MT's. Can anyone confirm this difinitively?
Also I got my car back yesterday, new shortblock, so I'll keep you all posted on how she does! I'm going back in another 1K to see if the oil issue has been solved. Also props to Infiniti of Tacoma @ Fife, they replaced my belts and my throwout bearing while it was in pieces and the car feels so much smoother on the clutch
Old Aug 27, 2010 | 10:42 PM
V35 Skyline GT's Avatar
6MT Coupe
^ Congrats on your short-block replacement. You ever get the TSB number for that change from long-block TSB....
Just remember, you may/will consume some oil during break-in period while rings are seating/sealing which is normal.
Old Aug 28, 2010 | 01:27 AM
jookyshank's Avatar
I haz hugz to givez
Nissan never said it was a new TSB (not sure how that works) but just an update to the existing one. They were also quite smug about not telling me as TSB's are for "internal use" and should not be available to the public. Have they ever even SEEN the internet? yeeshh
Old Aug 28, 2010 | 10:41 AM
6MT Coupe
^They've been known to revise existing TSB's, happens often. The long-block TSB I know of and posted on other thread is its third revision.
Agree, dealers HATE when customers are knowledgeable and have access to TSB's. Takes the wind out of their sails and can't BS the customer...as bad, but many still try lol. I kept a copy in my back pocket every time I came back during my OC testing. I countered them many times with their BS games/excuses....long story short I finally won per 'their' TSB guidelines. The irony
Hoping your replacement is a winner
Old Aug 31, 2010 | 02:38 PM
vp-g's Avatar
I did the OC test, dealer changed the oil and marked the dip stick above the H.. but when I return they said they go by the H mark not the actual mark they put..? Is that how it works?
Old Aug 31, 2010 | 03:00 PM
broke_as_ajoke's Avatar
This is not really clear to me. So I just call the dealer and tell them i want to have my car checked. (i have an o7 with At and about 51K on it. No mods as of yet) So after they test the OC.. if the car fails the test do they replace my motor with the same style motor or do they give me an improved motor?
Old Aug 31, 2010 | 03:02 PM
vp-g's Avatar
^^did they explain how you failed? ask for a long block..
Old Aug 31, 2010 | 03:05 PM
  #30
irishsig's Avatar
The vast majority of the OC issue is with the revup 6mt (05-07).
I have heard of some people having the OC issue with auto trans but is not that common.
Just check ur oil level yourself.
The hassle of taking in your car and trusting that the dealership will be straight with you is very unlikely.
I would still love to know what % of revup 6mt Gs have the OC problem.
I've never been able to find this out in my research.
