TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Cooling fans kicking on frequently
Old Sep 23, 2012 | 12:49 AM
renzog35's Avatar
Red face Cooling fans kicking on frequently
So I'm the new guy on this forum because I am seeking help. And because it is an awesome site which helped me get my car to where it is now. So.... I have a 2005 g35 sedan. It has 96000 miles on it, It started overheating on me. So I did a bunch of research (mostly on this site) and figured out it was the thermostat. Changed that out, it was still overheating. Learnt about air pockets in the cooling system...put my car up on ramps, used the release valve near the firewall, and my heater started blowing hot air again. Temp was right where it should be...super stoked. I Thank all of you on this site for the advice that got me to this point. My dilemma now is that the cooling fan( really LOUD ) comes on all the time. It never did that before I changed out the thermostat. Can anyone give me some advice? Please and thank you fellow g35 owners.
Old Sep 25, 2012 | 04:09 AM
renzog35's Avatar
Not one post. Help me out brothers!
Old Sep 30, 2012 | 10:22 AM
sandaluv's Avatar
im having similar issues. i did a coolant flush and got air in the system so i had to bleed it. at first everything was fine but now the fans kick on way too often( a/c off, normal driving). lets see if anyone can chime in.
Old Oct 7, 2012 | 10:17 AM
renzog35's Avatar
Thank you Sandaluv! Finally someone who can relate.I'm wondering if it is some kind of sensor. Same here...normal driving, As soon as it starts to heat up, the fans kick on and they don't shut off. The temp gauge stays right where it should be, happy about that. Where are all the Infinity tech guys? I guess the info I pulled from this forum was from over 3 years ago, so those guys may have moved on. Any advice will help...thanks
Old Oct 7, 2012 | 11:24 AM
sandaluv's Avatar
Np Renzo. i think youre right about the sensors as our fans are electric. question is, is it normal? i might just bite the bullet and take it into the dealer, get a diagnosis, and do the repair myself. this is what ive been doin since i bought the car and so far, with help from this forum, ive done all the work on my car with no issues. i will post the dealers diagnosis on here for you so check for my reply.
Old Oct 7, 2012 | 12:09 PM
EbbAndBlow's Avatar
The fans shouldn't be too loud unless the bearings are going out or some other mechanism for moving them is beginning to go. Give that a look if the sound isn't just the rushing of air through the blades. Then again I have a 2nd gen sedan and mine may be quieter?
Old Oct 7, 2012 | 11:51 PM
renzog35's Avatar
Awesome man thanks! I will keep doing research on my end. I know a few people who may be able to help me out. I will post any results as well.
Old Oct 7, 2012 | 11:57 PM
renzog35's Avatar
The sound it produces is normal. I don't think the fans are bad, they just keep kicking on frequently and won't shut off. I believe you have the 4th gen, while mine is the 3rd. I could be wrong though. Not sure they would make drastic changes on the cooling system.
Old Oct 8, 2012 | 12:49 PM
sandaluv's Avatar
i agree . i dont think its bearing related. the fans are loud yes but what our issue is their frequent and unnecessary operation. in my limited mechanical knowledge im leaning towards a heat sensor of some sort. our engines run pretty hot so maybe its something we must learn to live with. this is rather unusual in a luxury car imo. thnx ebbnblow for response.
Old Dec 9, 2012 | 08:54 PM
ThatOneDude's Avatar
I'd like to BUMP this because I'm having similar issues. After having the radiator and thermostat replaced, my radiator fans are constantly running super loud... It's not a huge problem but definitely annoying so if there's a possible fix, I'd like to hear it...
Old Dec 13, 2012 | 08:47 AM
rsingerG35's Avatar
Was an OEM thermostat used?
KallDay86
Jan 8, 2016 12:42 AM
dseet
Oct 11, 2015 12:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jay123
Sep 28, 2015 08:42 PM
mattdg35
Sep 14, 2015 11:28 AM
