TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
HELP!! I think I have bad pdu
Old Sep 15, 2020 | 11:37 PM
David Munoz's Avatar
m35s vq35 off an 06 g35
Angry HELP!! I think I have bad pdu
Spoiler
I think I have a bad power dristribution unit my cars start when is wants and when is does headlight turn off on when they want ac turns off radio does also it reads key I lost when it wants ivd checked all fuses and plugs there some to be fine I got a new battery and still the same way not sure if I should spend the money and the problem won’t get fixed anyone else have experienced this problem
Old Sep 16, 2020 | 01:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like a wet IPDM, it's the big fuse box next to the battery.
Disconnect the battery, disconnect the IPDM, take a picture of the fuse/relay layout on the IPDM, disassemble it COMPLETELY and look for moisture inside it, yes that means take off the back half cover so you're down to the circuit board.
If it's wet put it in a bag of rice to dry it out just like you would do with a wet cell phone, when you reassemble it make 100% sure the front cover snaps on properly.
Then fix the cowl drains so it doesn't spill water on the IPDM, the cowl drain is notorious for plugging up with debris.
gkeylow
Dec 16, 2017 03:36 PM
Fonz
Dec 10, 2016 08:42 AM
97prelude
Aug 9, 2012 01:04 AM
afG3580
Aug 3, 2012 01:59 AM
raskizzo1
Feb 18, 2008 07:42 PM
