Utec Or Reflash?
Old Dec 12, 2006 | 10:24 PM
G-TWIN's Avatar
Question Utec Or Reflash?
First of all i'm tt with about 8-9psi of boost. I can't decide wheather to go with utec or should i do a reflash? what do you guys think? what are some of you running on your fi setup?
Old Dec 12, 2006 | 11:10 PM
QuadCam's Avatar
UTEC for certain.
the utec will allow you to make changes to your setup. If you go the reflash route, any changes you make (and you will!!! no one leaves an FI kit alone. ) will throw off the tune.
Old Dec 13, 2006 | 03:57 PM
Old School's Avatar
ur boostin without management? not very smart...better get a UTEC - FAST.
If you can afford it, get an FCON
Old Dec 13, 2006 | 04:10 PM
izmir41500's Avatar
G35driver Addict
Utec
Old Dec 13, 2006 | 07:11 PM
Audible Mayhem's Avatar
get a utec, hands down, if you are in the florida area or need someone to find a good place to locate one, then pm me please and i can help you out.
thanks man
Old Dec 13, 2006 | 11:00 PM
G-TWIN's Avatar
Can Somebody Tell Me The Advantages Of Going Utec Instead Of A Reflash? Any Pros And Cons On Both. And Do You Need Any Other Stuff To Use For Boost.
Old Dec 14, 2006 | 06:29 PM
2slo2bfurious's Avatar
I think the guys already answered your question, but with a Utec you or a tuner can actually tune the car, with a reflash your "tune" can't be altered unless you send it back for another reflash and some $$ whenever you add some more things to the car.... Get the utec, or some ems at least. Doesn't all TT kits come with some sort of ems?
Old Dec 14, 2006 | 10:42 PM
QuadCam's Avatar
with the UTEC, you will need the MAP sensor if you are going forced induction.
the map switch is optional, but nice.
also, the tuner wibeband is not necessary, unless you are a tweaker.
Old Dec 15, 2006 | 12:08 AM
ballisticus's Avatar
I would do the TS reflash for the 100% open throttle, 7100 rev limit, speed limiter removal, and have them get the F/A ratio in the ballpark based on a dyno run. Then add the piggyback UTEC to really tweak it.
Old Dec 15, 2006 | 11:08 AM
G-TWIN's Avatar
i've already done the TS reflash for 8-9 psi. now i'm changing the exhaust from a single to dual (3 inch) ehxaust to a svrtech true dual with an X pipe ehxaust. i'm looking more in to this utec. where the best place to get and to go get it tuned? i live in 93263 zip.
Old Dec 16, 2006 | 12:54 PM
Oh, I didn't see anywhere that you had already reflashed. Anyway, you can buy the UTEC here http://www.turboxs.com/shop_prod.php?what_category=3
I'm sure if you search, you could find it for less, but that site is home for the product and if you call they can direct you to a tuning center. Good luck.
Old Dec 18, 2006 | 06:59 PM
TurboKits.com's Avatar
A reflash is a very nice way to easily get your car in the ball park for the mods you have. However, nothing can replace tuning to your specific application. You almost always end up with better #s all around. HP, Tq, 1/4 Mile, MPG, etc... Just make sure the tuning is done by someone who knows the engine and the software.
Jesse
esotericrider
Feb 14, 2022 07:19 AM
Joe Gargano
Sep 18, 2015 11:17 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
