I was wondering alot of the members here uses the utech piggyback or the reflash ecu which one is better and wat different does it do to the car so holla
Depends on what you want to do... I really don't see much point to the UTEC for NA now that Osiris exists.
Do a search for 'UTEC' and for 'Osiris' and read up on a few threads - there's tons of info already posted.
That is true, there are a number of other options if you stay N/A. But if you have plans to boost it get a UTEC or better (HKS, AEM).
Quote:
-Sean
That is probably true at this moment, but after UpRev's Tuner Kit is released, it might be a different story. Originally Posted by Nismo G
Even if you are not going FI u-tech is the way to go.-Sean
The Tuner Kit will let Tuners tune an NA G the same way they would tune with a UTEC... plus a flash tune can raise the speed limiter... change the RPM limit... and reprogram the electronic throttle control. ...plus you don't have to buy a UTEC and cram it in under your dash.
Additionally, a flashed ECU will not learn/unlearn anything. It will always be learning to your desired tune.
Osiris for NA...
UTEC for FI...
That's how i'm going. Plus, I get the cipher with the Uprev Osiris
UTEC for FI...
dofu
close
- Join DateSep 2005
- LocationSilicon Valley
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:242 Times in 197 Posts
From the researching I'm doing, I've found this: The Uprev Osiris is only tuned at WOT, and the UTEC only takes over at WOT.
My concern is that I'm not always at WOT when I drive. I would like something tunable like the UTEC, but I'm not boosted yet so something like the Greddy eManage would be a bit overkill. So right now, the Osiris and any fuel controller sounds like a better option. But would the Osiris keep my ECU from adapting to and overriding my APEXi fuel controller?
