just dynoed
Old Mar 20, 2004 | 01:54 PM
tig488's Avatar
just dynoed
well the vortech installation is about to begin so i figured id go get a baseline dyno before the sc, i say baseline but i have and injen CAI and the injen SES, i had my zex installed but didnt use it because i had taken my bottle out, (doh!), anyway i paid 60$ for 3 pulls, some pics are below.
started with 230hp, ended up with 235.4, with no adjusting, just back to back pulls, plus because some of his business neighbors have complained about the noise so he had to put the large exhaust plumes on, he said you lose about 7 hp with those on, it was pretty hot, about 86 degrees, air/fuel looked great, it did run a little lean at the top end.
for some reason my slip light stayed on for a while afterwards, than kicked off later, anyway enjoy the pics.
BS/Graph 6MT Cp
19" GunM TE37 275/30 MPSports
kg/mm,cambers,cuscosways,injen int/exh,Alpine/JL/Stinger,topsecret
Vortech
Old Mar 20, 2004 | 02:08 PM
tig488's Avatar
Re: just dynoed
pic2
BS/Graph 6MT Cp
Vortech
Old Mar 20, 2004 | 02:14 PM
tig488's Avatar
Re: just dynoed
pic3
BS/Graph 6MT Cp
Vortech
Old Mar 20, 2004 | 02:16 PM
tig488's Avatar
Re: just dynoed
pic4
BS/Graph 6MT Cp
Vortech
Old Mar 22, 2004 | 02:51 AM
RavenR's Avatar
Re: just dynoed
nice...looking forward to those SC results....
Ivory Pearl Coupe/5AT/Aeros/Premium/Nav/Type-N Front Bumper/Z-Tube+Popcharger/V1
Old Mar 23, 2004 | 10:29 PM
Baumer's Avatar
Re: just dynoed
we'll definitely need to have that meet once you get the vortech and top secret front end on.
where are you getting the sc install done?
6MT Coupe
NAV-TV, PS2, JL 12W6v2, JL 500/1
Injen CAI, Borla Exhaust
Eibachs, S9000s, Volk SF-Challenges
Old Mar 24, 2004 | 03:01 AM
RedefinedG35's Avatar
Re: just dynoed
hey glad to hear the numbers man you should have called me i got my gauges in i should have that bottle hooked up soon... hopefully if everything goes well and i need to dyno soon too.. i'm plannin to go to lassiter tomorrow night (Wednesday) and see if i can get a few good runs in... yeah can't wait til you get that SC and Top Secret bumper in... man i'm gonna wet my pants lol
Old Mar 24, 2004 | 12:15 PM
PimpinPearl's Avatar
Re: just dynoed
what was the weight of the car you used when dynoing and did you tune it in 4th gear and what mph did you start recording at?
Ivory Pearl / 6MT / Aero / Premium / Xenon Lights Everywhere / Mirror Tint / Injen CAI / Injen SES Exhaust / Tanabe Racing Springs / Ground Wire Kit / Apex'i S-AFC II
Old Mar 24, 2004 | 02:50 PM
KPierson's Avatar
Re: just dynoed
You're slip light most likely stayed on because you did not shut VDC off before your dyno. This is a problem (for the VDC system) because it monitors ALL four wheels when the car is running. If it sees that your rear two whees are rotating at 100 mph and sees that the front wheels arn't moving it probably faults out since this isn't likely to happen in the 'real' world. The Slip light will stay on until you shut the car off and let it set for a while, then start it back up. I had to restart mine about 5 times before the light shut off! I'm sure it's just a diagnostic thing, and nothing to worry about!
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
Old Mar 24, 2004 | 10:09 PM
tig488's Avatar
Re: just dynoed
i dont know the weight he used, i know it was in 4th but dont know the mph, on one of my dyno sheets it recorded mph which was 106 i think, as far as the slip light, we did turn vdc off the first run, but i bet he didnt on the last 2. so youre probably correct. i forgot to tell him on those 2 runs.
BS/Graph 6MT Cp
Vortech
Old Mar 27, 2004 | 08:56 PM
sniperinaG's Avatar
Re: just dynoed
<hr></blockquote>
Just a little FYI:
The weight of the car has nothing to do with the dyno numbers! The dyno measures actual torque. That's it, and A/F should you choose.
Looks like you are a bit rich acroos the board on those runs. You could lean it out a little for better response. But seeing as you have the zex kit, better to leave it alone.
Also you can see he started at around 2500 rpms. Mph does nothing either on a dyno. Which gear doesn't make but only a slight difference. To use lower gear runs out real fast.
Old Mar 27, 2004 | 11:16 PM
KevinG35's Avatar
Re: just dynoed
Shouldnt you be in 5th gear on your 6MT? That is the 1 to 1 ratio for that tranny. Numbers might be off if you use any other gear.
KevinG35
2003 Diamond Graphite G35 Sport Coupe, 5AT, Premium Pkg, Performance Pkg.
Old Mar 27, 2004 | 11:48 PM
zimbo's Avatar
Re: just dynoed
The gear doesn't matter that much, actually. However, for A/F tuning purposes it's my observation that 5th gear is best on a DynoJet dynomometer because it puts the most load on the car. On a DynoPack there's no difference whatsoever between 3rd and 5th in my experience.
--Steve
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
