Tuned at Uprev this morning 2006 5AT coupe
Old 08-21-2009 | 10:28 PM
Petoria's Avatar
Drove up to uprev in austin to get Osiris and dyno tune. Wasn't the gains I was expecting but they're gains. I was running really lean before this so Jared fixed everything to make it run right but we still didn't get the power that was expected, only +6 hp. At least it's not running super lean any more. I've been driving like this with all the mods for almost a year, so that's almost a year running super lean (can't be good) Overall, still happy I made the trip.
Mods:
Impul Exhaust with mid pipe
Motordyne XYZ pipe with resonator
MD 5/16 Spacer
Z-tube/ KN filter
FI 300 cell Cats
Dyno sheet:
Old 08-21-2009 | 10:34 PM
Skaterbasist's Avatar
Retired SuperMod
Revup or non-revup?
I gained great results from the Osiris tune on a revup with the following mods: 5/16 spacer, MREV2, test pipes, exhaust, stillen intake.
Your gains aren't bad (but not great). You did gain power all around, so that's good to see.
Old 08-21-2009 | 10:36 PM
thescreensavers's Avatar
Mr.202?
Originally Posted by Skaterbasist
Revup or non-revup?
2006 AT coupe= non revup
Old 08-21-2009 | 10:44 PM
Retired SuperMod
Whoops, missed that
Did you bother getting a high octane tune for a separate map?
Old 08-21-2009 | 11:17 PM
Petoria's Avatar
yeah map 1 was for 93 octane. Gains arent much but it's somethin
Old 08-22-2009 | 12:15 AM
Retired SuperMod
high octane meaning 100+ (aka race gas)
Old 08-22-2009 | 12:39 AM
Petoria's Avatar
ohh...nope, no high octane gas map
Old 08-22-2009 | 02:22 AM
lilindienplaya's Avatar
dont we have more then 243hp stock
Old 08-22-2009 | 02:59 AM
Retired SuperMod
243 stock can be 220 on another one.
Dyno's are not meant to be compared with one another unless they are of the same exact machine.
Old 08-28-2009 | 03:46 PM
Sentientbydesig's Avatar
Since when is 14:1 lean? stoich is 14.7:1. I believe my coupe, will spike up to 17:1.
Old 08-28-2009 | 04:28 PM
sloppymax's Avatar
Stoich is fine at idle and partial throttle, but not at WOT. If you are hitting 17 and the reading is accurate, you are headed for failure.
OP- If you were running lean over a decent period of time, I would seriously consider checking/replacing the plugs.
Old 08-28-2009 | 05:28 PM
GT-ER's Avatar
I don't think you can even have a combustion at 17:1.
Old 08-28-2009 | 05:36 PM
Retired SuperMod
Wave your engine goodbye.
Ideally a VQ at wide open throttle should be around 13.0 and get a little richer up high RPM's [6k-7k].
Anything in the 14's and above is running lean. I can assure you you are not at 17.1 during WOT. That is a definite quick death sentence for the VQ.
Old 08-28-2009 | 05:51 PM
xx7sephiroth7xx's Avatar
G
Just +6 HP?
While that is certainly not a loss and definitely a gain...
Old 08-28-2009 | 05:55 PM
03threefiftyz's Avatar
Peak of 6 and looks like up to a max gain of ~10. Not bad.
Quick Reply: Tuned at Uprev this morning 2006 5AT coupe
