Ecu tuning 2002/2003 g35sedan (very technical)
Old Jan 1, 2011 | 02:42 AM
Eric@TCGMiami's Avatar
I have the entire pin out posted up there...
I forgot about that... out of sight out of mind ....
I will definetly make it a priority to get this done soon
Old Jan 1, 2011 | 12:51 PM
Tollboothwilley's Avatar
Emanage (ultimate or blue) both will allow you to tune both air/fuel AND timing. In order for timing to work with the BLUE you will need to have the ignition wire harness. If you have that you can fully tune timing.
I picked up 30 tq and 20 hp with my tune on the eManage.
Old Jan 11, 2011 | 08:10 PM
MM_G3520's Avatar
So is there a small group of 350z out there with the oddball ECU as well?
We hear about it on our G35s, but where are the "pissed" early ECU 350z drivers?
Old Jan 11, 2011 | 08:21 PM
NFSP G35's Avatar
? = 2B || !2B
^I didn't think this was an issue for coupes or Zs
Old Jan 11, 2011 | 08:46 PM
SurraTT's Avatar
any updates??
Here are my 2 cents not that anyone cares
This can be done relatively easy, I'm currently working on it for my maxima but its easier for the 03 g sedans because they are actually set up for the newer style ecu (black ) connector they just got shafted on their ecu. While the maxima ecu actually controls a few more functions and does a few things differently. A 03 g sedan ecu has the same plug type as a 02 03 maxima but it actually dont function the same.
The only issue i seen when i looked into it was the NATS system, even that might work just fine.
What you would need far as i knwo ( i dont have a 03 g sedan to test on)
new black connector style ecu, one that uses factory narrow band o2s
a adapter harness that converts your factory harness (grey) to the new black ecu and puts the wires in correct location.
Then depending on NATS working or not, you might HAVE to get osiris , which could disable nats if it could not function normally. (I think nats will work just fine itll just have to be programed at the dealer)
In the NEAR future im going to explore this more, but id need someone with a 03 g sedan to test.
Old Jan 11, 2011 | 08:52 PM
NFSP G35's Avatar
? = 2B || !2B
^I'd buy a newer ECU if there was an adapter harness available.
Old Jan 11, 2011 | 08:56 PM
SurraTT's Avatar
If its possible ill def do it. It def wont be any harder than trying do it in a maxima!
Anyone with a 03g sedan local to NC?
Old Jan 11, 2011 | 09:27 PM
didnt have issues on the 350Z. when the first 350Z was released the G35 sedan had already been out for 6 months. Nissan "threw" it out the door with the older ECU. Clearly they wanted future models to have the newer and better ECU just didnt care for the new buyer in late 2002 :'(
Old Jan 12, 2011 | 11:18 AM
hashrock's Avatar
Hey SurraTT - I'm in Raleigh with an 03 doggy door. I'm a little scare of what you're going to do with the ECU
Old Jan 12, 2011 | 11:56 AM
SurraTT's Avatar
Ohh ok cool, i just moved from Burlington to Greensboro so im a lil further away now. Haha. well basically ill make a harness that adaptes your old grey ecu harness to a new plug the black one, and use a black connector ecu.
I'm not sure how familiar you are with this stuff, and if your car is modded and you want to tune or not. If so a ecu swap to the black connector would be perfect. send me a email if youd like to talk about this more and possible test it out.
Old Jan 12, 2011 | 12:41 PM
Updates are:
Going Full Standalone..
This won't work as the newer ecu handles less functions than the 2003 so you'd have to rewire the entire car.
Old Jan 12, 2011 | 12:45 PM
NFSP G35's Avatar
? = 2B || !2B
What about a partial piggy back using the newer ecu?
Old Jan 12, 2011 | 12:56 PM
SurraTT's Avatar
Originally Posted by Eric@TCGMiami
Updates are:
What would those be?
What standalone are you going to do?
Old Jan 16, 2011 | 06:38 PM
SurraTT's Avatar
Any details other than it wont work and need to rewire entire car?
Old Jan 16, 2011 | 06:51 PM
  #30
https://g35driver.com/forums/tuner-d...y-doors-2.html
