Should I get a tune now?
Old Mar 26, 2011 | 03:35 PM
Manual G's Avatar
That's more then I expected from a tune with just a z-tube/axle back. I would also like to know if that was an osirus tune.
Old Mar 26, 2011 | 04:12 PM
seymore4's Avatar
m56
Yes this was Osiris!
Old Mar 26, 2011 | 04:41 PM
almost3flips's Avatar
I'm not sure because I haven't heard the straight pipe version myself, but I would probably still go resonated.
Seymore - you're convincing me to just get the tune. Do you know how much power a catback would add on top of the y pipe in the future?
Old Mar 26, 2011 | 05:38 PM
seymore4's Avatar
m56
realistically 5-10 whp, it'll be very fun tho
Old Mar 26, 2011 | 06:00 PM
wanagofaster's Avatar
Was it a revup or non revup
Old Mar 26, 2011 | 08:25 PM
seymore4's Avatar
m56
2005 rev-up, 6MT
Old Apr 4, 2011 | 04:41 PM
RyguyG35coupe's Avatar
What up seymore4!? Hey, I'm located in Portland as well. Where was that tune done, Forged Performance (Troutdale)?
Old Apr 4, 2011 | 04:46 PM
seymore4's Avatar
m56
Whats good man, me and a couple other portland guys are trying to get some meets organized down here once the weather gets better, check into the regional section!
The only place to get work done is Intec Racing in Kent WA, they do serious work on VQ's and stand behind it 100%. As a matter of fact there's 3 G35/350z's scheduled to dyno tune this week alone, Lawrence really knows his ****!
Old May 11, 2011 | 04:33 PM
seymore4's Avatar
m56
how'd it turn out OP?
Old May 11, 2011 | 06:54 PM
I just decided to wait to get everything. I actually bought a topspeed exhaust and motordyne art pipes ha. Waiting on a shop to open around here to tune
Old May 11, 2011 | 07:43 PM
seymore4's Avatar
m56
you're in fort worth? Take it to Uprev and let Jared tune it, thats ground zero for VQ tuning lol Google says its only 3 hours away, definitely worth it IMO
Old May 11, 2011 | 07:47 PM
So austin is the best place then? I'm about to pull the trigger on a differential so that will kill my funds as I'm trying to get ready for the track this summer. The tune is being delayed for quite a while now ha. Would I be okay or would I be running too lean o_O
Old May 11, 2011 | 07:50 PM
I also saw that you were saying Greddy spark plugs were better for n/a? What are the pros to using them over the stock spark plugs?
Old May 11, 2011 | 08:12 PM
ratm68's Avatar
if you're not planning on getting a catback in the near future, i don't think you're going to miss out on much. For N/A, you will get gains from a tune, but it won't be more than 20hp if you're lucky.
Old May 11, 2011 | 08:37 PM
  #30
seymore4's Avatar
m56
We've seen the best results with the Greddy L7's, they're colder than stock and have a more consistent spark. You'll be fine even with OEM replacements, but will sacrifice a little bit of performance. If you're not getting the tune tho I wouldn't spend the $$. The biggest thing is to make sure that they are fresh before the tune; our cars are notorious for destroying plugs.
Uprev's headquarters is located in Austin, that is where you would be taking your car, if they can't tune it NO ONE can.
You won't gain so much "peak" horsepower, but with the syncing of the throttle (doesn't open 100% from the factory) and calibration of the A/F and timing you will gain a lot of usable and noticeable power throughout the powerband, very worth it. Unless you've got a completely open dif right now the tune will give you more benefit, IMO.
I have talked to over 20 people before and after their tunes at Intec Racing in Kent, every single person has come back with a huge smile and agreed that it was the most worthwhile mod they've done. I would also advise against tracking the car hard if you have breather mods/exhaust etc, I can almost guarantee you're running lean.
