Should I get a tune now?
Old May 11, 2011 | 08:57 PM
  #31
almost3flips's Avatar
I'm definitely getting a tune no doubt about that. I guess I'll just have to wait to get everything done before I get out on the track.
How much more performance are we talking here with the spark plugs? The greddy plugs are going to be $150+ as apposed to the $50 oem plugs.
For what I'm doing, the rpms are going to be in the mid range to high rpms so running lean won't be too good for it correct? I know I'll be lean but how bad is it on a n/a motor as opposed to FI?
Old May 11, 2011 | 09:43 PM
  #32
seymore4's Avatar
m56
It really depends on the car, if you are curious take it to a local shop and do some dyno pulls and check the A/F, they'll be able to tell you. Had one local guy come to a dyno day with a LOT of misguided mods, he was running so lean you could hear knock in the parking lot, couldn't even complete the dyno pull. This is an extreme case however.
I'd say the greddy plugs will get you an extra 5-10%? Don't have any exact #'s, might do that this summer if I get bored.
Old May 11, 2011 | 09:51 PM
  #33
tahts actually a very nice number. Is it just because they are a step colder or just from the way they are made?
Old May 11, 2011 | 11:32 PM
  #34
seymore4's Avatar
m56
Wait, that may have come off wrong, I don't mean 5-10% total (25whp) but 5-10% of the gains, so 2-3whp difference. Its a combination of factors, some being the consistency and quality of the spark, as well as the heat range, you can push timing more aggressively with the colder plugs and make more power with less knock, from our experiences.
Old May 12, 2011 | 12:18 AM
  #35
I think I will go ahead with the tune before I get the differential. No need to rush into something I won't need just yet. What is the full name of that Greddy spark plug?
Old May 12, 2011 | 12:35 AM
  #36
I've been told and have read that its safer to stay with the stock plugs. What are your thoughts?
Old May 12, 2011 | 11:23 AM
  #37
seymore4's Avatar
m56
They're the Greddy L7, and how could it be "safer" to stay with stock plugs? I call BS
Old May 12, 2011 | 11:58 AM
  #38
saying that since the engine is used to that spark or something? I'm not sure. I usually see people saying stick to the oem plugs but I am not sure why. How many cars do you know of that have made the switch to the Greddy plugs?
Old May 12, 2011 | 02:16 PM
  #39
seymore4's Avatar
m56
Personally about 15, but like I said the gains will be negligible if you're not getting a dyno tune
Old May 12, 2011 | 02:47 PM
  #40
Know of any deals on the Greddy Plugs?
Old May 12, 2011 | 03:22 PM
  #41
seymore4's Avatar
m56
PM'd
Old Sep 23, 2011 | 01:02 AM
  #42
Update: I got the tune and ended up with 27 hp gain and 17 tq gain
Old Sep 23, 2011 | 12:40 PM
  #43
Eno's Avatar
Eno
Glad you got it done and see some healthy gains as a result. How's the butt Dyno reading?
Old Sep 23, 2011 | 12:42 PM
  #44
The car is very responsive to how much throttle I apply. It is even more fun to drive now. Tune was the best thing I've done to my car because it also saved my motor. I had a knock and was running super lean O.O
Old Sep 23, 2011 | 09:15 PM
  #45
Algy's Avatar
Are you located in Texas? If so did you go to Uprev in Austin? and what was baseline and after tune numbers?
