302.4 whp
Old Sep 28, 2011 | 08:40 PM
  #76
zeroscythe's Avatar
It's safe but pointless considering our cars don't make power that high in the power band without at least having new cams
Originally Posted by Algy
why is no one answering my question about if it is safe bumping up the rev?
Old Sep 28, 2011 | 09:38 PM
  #77
butkiss1's Avatar
Stock redline on a 5 AT is 6750
I make power to about 7000.
Shift at like 7050/7100
Been tuned for like 3 years now.
No problems related to the tune at all
Vq35de is tougher than u think
Old Sep 28, 2011 | 11:21 PM
  #78
Algy's Avatar
So you are telling me my tuner didnt know what he was talking about? I could of bumped up my stock rev up higher???? without upgrading the valve springs or valves or cams?!?!
If so Im going to call uprev and tell them they didnt even increase my rev!
Old Sep 28, 2011 | 11:35 PM
  #79
Algy's Avatar
I thought yours was at 7600? And you have no new valve springs or valves or cams? and it runs up there just fine?
  #80
butkiss1's Avatar
When I first got tuned Shawn Church told me that he bumpedup to 7600 I was extremely concerned. But after a few conversations on the subject, I conceded to his knowledge.
your tuner was probably not that familiar with the Vq engine. The tachometer reads high. Nissan designed it like that.
Old Sep 28, 2011 | 11:39 PM
  #81
butkiss1's Avatar
It is set it 76 but I shift at 71
Old Sep 28, 2011 | 11:50 PM
  #82
Algy's Avatar
Yeah when i look at my dyno charts, it drops off barely at 6750.... more like 6650... ugh.. when i look at your dyno charts it drops at 6900-7000.
Also when I rev it doesnt even go passed 7. like you said if it read higher and it was set at 7 like the tuner told me, i would have been reading 7100 or 7200.
Old Sep 29, 2011 | 12:04 AM
  #83
butkiss1's Avatar
Higher Rev only works in tip mode
Old Sep 29, 2011 | 01:30 AM
  #84
Algy's Avatar
Already know that.
Old Sep 29, 2011 | 10:35 AM
  #85
OCG35's Avatar
yes - not only is it safe, it is very common...
Technosquare determined years ago that 7100 is the safe limit for first gen DE (for those that dont know, Technosqaure was the first to crack the ECU and was the only tune available for several years)...
Beyond 7100 it is advised to upgrade valve springs, oil pump and rod bolts... cams and valves have nothing to do with the safety of higher rev limiter - but can be part of helping take advantage of power in the upper end...
The reason people bump rev limiter (to safe limit) on stock internals is to max out revs and the drag strip so that you can finish the 1/4 mile in 3rd gear (shifting to 4th will fubar the entire run).
All of this is very old information, very much common knowledge to many of us that have been around a while... and have been racing and modding Gs for a while...
BTW, UpRev bumps rev limiter too... I have no idea why they wouldn't have bumped yours
Old Sep 29, 2011 | 10:37 AM
  #86
OCG35's Avatar
see post above about 1/4 mile in 3rd gear...
granted, I dont know why MT do it (and I dont care cause I'm not MT)...
Old Sep 29, 2011 | 01:53 PM
  #87
zeroscythe's Avatar
yea I didn't think about it in a drag race sense but I can see how it'd be necessar.. on stock internals tho and with our restrictive stock plenum it's very difficult to keep making power that high up in the band
Old Sep 29, 2011 | 07:17 PM
  #88
KingCobra's Avatar
no since we were just testing our lower plenum.. But we do have a ported and gasket matched lower collector that i'd like to use next time.. But yea we should definitely see better gains on a rev up.. Now it's just a question of finding someone with a stock rev up for some dyno time
Wonder if you guys will get better numbers than Motordyne...keep us posted!
Old Sep 29, 2011 | 07:26 PM
  #89
KingCobra's Avatar
As others have pointed out, its alot harder to launch a manual than autos who simply just stomp on the gas and dont worry about anything else...why do you think theres so many videos of slow cars "beating" others cars like OMG I'm a civic and i just beat a porsche when you can clearly see that the other guy either didnt launch right or missed a shift....it takes a lot more experience to actually perfect the launches and shifts in a stick shifts to get the best times possible as opposed to an automatic where anyone can just jump in any type of car and get pretty much all the best time that auto car can run...
I wouldn't brag about beating a stick shift with like 10hp more, go to the track get your best time for the day, then compare...I also don't know why you would raise your limiter to 7600 when you shift at 7100, i guess just another thing to brag about haha
Nonethless cool numbers, I'm sure I'll get to those numbers with the mods i have planned -_-
Old Sep 30, 2011 | 09:43 PM
  #90
Algy's Avatar
Well I took my car back to uprev today. Got the rev bumped up to 7200. Apparently it was already at 7000... not to me.. bc I compared it the stock map and the dyno sheets.. it rev the same. Now with the bump of 7200 its a world of a difference IMO.
