Dyno'd today - Here are the #'s
Old Feb 18, 2006 | 07:34 PM
SWAT311's Avatar
I just got back from Church's. This was my first dyno, so I'm not too sure if the numbers I pulled were good or bad. If anyone care's to comment (good or bad) with suggestions that would be great. And also, what else can I do to add power but STAYING N/A. Thanks-
Jonathan
P.S. Mods are in sig.
Attached Thumbnails Dyno'd today - Here are the #'s-scan012-february-18-2006-2.jpg   Dyno'd today - Here are the #'s-scan013-february-18-2006-2.jpg
Old Feb 18, 2006 | 09:08 PM
99atlantic's Avatar
seems pretty good for an a/t w/ just spacer, exhaust and headers.
Old Feb 18, 2006 | 09:55 PM
richie's Avatar
hey Jonathan, doesn't say in your sig if you got the technosquare reflash or not... did you ever get a reflash, your AFR looks linear (good)?
Old Feb 18, 2006 | 10:33 PM
OCG35's Avatar
Very good TQ! HP is not bad.
Old Feb 18, 2006 | 11:03 PM
crypten's Avatar
Nice are some nice numbers. After getting all your mods done, did you get your car tuned?
Old Feb 18, 2006 | 11:09 PM
codeflux's Avatar
those are *crank* numbers - 260... should be higher than that. my 5AT sedan pulled 275 crank hp at 6000rpm on dastek dyno. should be higher than that... you might want to have your G tuned - i'm doing mine in about a month or so.
Old Feb 18, 2006 | 11:24 PM
absolutg's Avatar
workin...
didn't randy say that church's dyno is rahp, rear axle hp, and not crank.... basically you take the wheels off.
Old Feb 19, 2006 | 12:26 AM
SWAT311's Avatar
No, I have not had it reflashed yet. I wanted to dyno before and then after the reflash. What exactly does the reflash do? And what kind of gains, if any, could I expect?
Old Feb 19, 2006 | 12:28 AM
SWAT311's Avatar
Yeah.. they just pulled off the rear wheels, and hooked her up.
Old Feb 19, 2006 | 12:39 AM
SWAT311's Avatar
Are you sure about that ?
Old Feb 19, 2006 | 02:49 AM
Mr_pharmD's Avatar
how can u tell that dyno is crank and not whp? Those numbers looks really good but I would go with a dynojet next time to get more accurate hp/tq reading.
U can try getting hi flow cats/test pipe, 3.5 rear diff, and cams if u still want to mod your AT. GL
Old Feb 19, 2006 | 01:59 PM
SWAT311's Avatar
I'm really considering changing the rear diff. I don't know much about the rear diff, but I thought it was the 3.9 gears that helped NA's alot. Can anyone recommend a good place to purchase and have these installed?
Old Feb 19, 2006 | 03:03 PM
Driver Elite's Avatar
Anyone on this? I want to know the same thing as I have just about the same mods done and wonder if I would benefit from a tune. BTW, who would tune it?
Old Feb 19, 2006 | 04:10 PM
99atlantic's Avatar
..........i don't think they're crank....?
Old Feb 19, 2006 | 07:22 PM
trey.hutcheson's Avatar
Those are not crank numbers. Like randy said in another thread, those are rear-axle numbers.
