Auto Record with Music Box question
Old Feb 6, 2008 | 01:18 PM
richpearl's Avatar
Folks,
It's been over 2 weeks since I got it, and I'm still learning functions on my '08 G35x. One that is eluding me is the auto record function. I've set it to on, which should record CDs that I insert in the in-dash player.
In fact, it does record them, but they don't seem to show up until the next day or so. Is this normal? What's really happening? Is it that I have to turn off the car and turn it back on before the new CD appears in the Music Box?
Has anyone had a similar experience?
--Rich
Old Feb 6, 2008 | 01:42 PM
fecurtis's Avatar
Thats weird, when you record songs from your CD onto your harddrive, its uploaded immediately.
Do you name your CDs and tracks prior to burning them? A good way to find out if you aren't sure is to check your harddrive and play a song, if the song is simple titled (Track 1, Track 2, etc.) then you aren't naming your songs and you probably aren't naming your playlists, they'll all be named the samething "Unknown Album" which may make it difficult to locate the songs you just recorded, especially once you have several songs added.
Most burning software will allow you to edit the song titles and CD names prior to burning. This makes it a lot easier when trying to locate specific playlists on the harddrive. Hope this helps.
Old Feb 6, 2008 | 03:47 PM
richpearl's Avatar
Thanks for trying to answer
Do you name your CDs and tracks prior to burning them? . . .
I appreciate your answer, but the fact is that I've only loaded commercial CDs, not one's that I've ripped. I'm talking off-the-shelf, right-out-of-the-jewel-box CDs. They do record; they just don't show up at first.
I can't figure out what's going on. My best guess is that it's "user error," but I don't see what I'm doing wrong.
--Rich
Old Feb 6, 2008 | 03:59 PM
terrycs's Avatar
I don't think Gracenote will work with non-comercial CDs.
To the OP ... Have the music box set to play by album. Then turn the **** on the right to scroll though your albums. It should be there right away.
Old Feb 6, 2008 | 04:00 PM
Lemodular's Avatar
try turning that function off and do a manual record. A button will appear when you insert a cd giving you an option to record. Once recorded, eject the cd and see if it appears in your playlist. Sorry, I'm only suggesting that because I do not have mine on auto record.
BTW, if you accidentally insert a previously recorded disc (on the music box), will the music box make a duplicate or just will not copy?
Old Feb 6, 2008 | 04:01 PM
Lemodular's Avatar
It will on some, not sure why though.
Old Feb 6, 2008 | 04:08 PM
fecurtis's Avatar
Thats strange. I wish I could be of more help but I've never recorded fresh off the shelf CDs.
As for non-commercial CDs, Gracenote can read them if you're using the right burning software that allows you to edit track names, artists, and CD name.
Old Feb 6, 2008 | 06:54 PM
stevek247's Avatar
is it possible to copy over files from IPOD to the harddrive? or data CD to harddrive? (mp3 files)
Old Feb 6, 2008 | 08:15 PM
Lemodular's Avatar
No and No
Old Feb 6, 2008 | 08:17 PM
stevek247's Avatar
sounds useless to me... any other way to use this other then to copy from a regular CD? Pictures? videos? etc
Old Feb 6, 2008 | 08:21 PM
Lemodular's Avatar
sadly, just regular cd's.....it will be nice if someone could somehow hack the software to allow it play videos and display pictures
Old Feb 7, 2008 | 08:29 AM
richpearl's Avatar
Terry's tip worked
I think your tip set me straight, Terry. It was user error. Apparently, I had to press the repeat button to a setting like play all (didn't see the album setting). Once I did that, I could use the tuner **** to get to all the albums I'd recorded.
Thanks!
--Rich
Old Feb 8, 2008 | 07:24 AM
pedropedro's Avatar
Here is my experience with recording cd's to the music box. It will record and name commercial cd's, however those cd's generally are pre-2007 recordings. I have had a few record and have the names follow, but it is hit and miss. Generally if I buy a new cd, I'll use Roxio and burn a copy with the names. However, Roxio has two Titling options, one for the album name and the other for the artist. The music box, however, only reads whatever is listed in the artist box. So I put the album title and the artist name there. Sometimes the title is too long for the music box to show the entire "sentence", but at least it is something and the song titles are there for each song. There is a total work around using the compact flash slot to get the titles from your computer and then getting the music box to read the flash card and associate the titles with the missing ones, but it seems like a real long, pain in the *** process, so I just do what I said. You can find the work around instructions on the support pages at infiniti under music box.
Old Dec 23, 2013 | 07:08 PM
missilemonger's Avatar
IF you have "automatic recording" on and you insert a CD, does Music Box record all songs on the CD immediately (more or less) or record each song as it is played?
Thanks and have a good Christmas
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
