Where is the XM radio ID to reactivate?
Old Mar 29, 2009 | 11:04 PM
clubprodigy's Avatar
Hi everyone,
Please let me know if there is another post that answers this question. I searched for a long time and couldn't find an answer.
I just purchased a 07 G35S and would like to reactivate the XM Radio. I know that on Channel 0, you can find the XM Radio ID needed for reactivation.
However, XM is disabled from the Nav menu, since it's not activated.
I'm confused... I need to have XM activated to access the menu entry, but I can't activate XM at all since I can't get to the Radio ID without accessing Channel 0.
Any ideas?
Thanks!
Old Mar 29, 2009 | 11:57 PM
pczavala's Avatar
check your paperwork, it should be listed on the paperpwork or brochure.
Old Mar 30, 2009 | 12:51 AM
kool_yaar's Avatar
I think All you need to do is turn on your XM radio and go to Channel 0 and it should give you your XM Id on the screen
OR your car might not be equipped with XM radio in the first place? Under the LCD screen the first button on the bottom left where you have the radio fm am, does it say XM?
Old Mar 30, 2009 | 12:59 PM
It does include XM, and I have the dealer document that states that the car comes equipped with XM. One thing that I noticed in the manual is that it states that XM might not appear in the menu anymore once it's disactivated.
So the option for XM never appears, even though it has it...
I'll try looking in my paperwork again, but I didn't see it the first time around.
Do you think the dealer would have that info?
Old Mar 30, 2009 | 02:56 PM
LiptonUCF's Avatar
perhaps this is a silly answer but have you tried hitting the "am-fm-sat" button until it goes to XM? even if there is not an active sub you should still be able to get to channel 0 and even channel 1 for previews i think.
Old Mar 31, 2009 | 06:59 PM
Thanks for your replies. I started travelling today so won't get a chance to play around with the radio again. But I'll keep you posted... I swear that the option in the menu dissapeared, and was not available...
Old Apr 3, 2009 | 02:37 PM
Greekboy115's Avatar
Hey Club,
I am in the same shoes as you. I just bought an 07' G35 as well and was wondering the same thing. I am guessing it might not be equiped as an option on your G. When I scroll through my AM, FM, SAT menu the XP pops up then I just head to channel 0 as some others have stated and it gives me the code. I wonder if you brought it to infiniti if they can set it up for you even if it isnt available on yours.
Old Apr 3, 2009 | 02:46 PM
GR6RR's Avatar
i think its channel 1
Old Apr 15, 2009 | 12:26 PM
chairman25's Avatar
Is the XM radio tuner in your trunk? Could it be that the tuner was removed from the car, since your paperwork says you have it (isn't XM standard?). Or maybe the tuner is unplugged if it in your trunk.
Channel 0 gives you the radio ID so that you can call XM and reactivate.
If you bought the car new then you should have had a 3 month free trial, the dealer has to send the paper work to XM.
If the car was bought used, the old owner may have cancelled his subscription and that deactivated your radio. Call XM they may be able to help you. Everyone who told you to check with the dealer is correct, they should have the radio ID in your paperwork (it should also be in your manual documentation as a seperate insert).
Old Apr 16, 2009 | 05:52 PM
Done!
I got the Radio re-activated.. somehow it was disconnected. Plugged it back in, it shows up, look up my radio ID on channel 1, and it how works!
Thanks everyone!
Old Aug 17, 2010 | 09:23 PM
TPLGT's Avatar
im having the same problem with XM. Bot my 07 G35s yesterday, called XM to send the signal no channel 1. I can get the ID from 0 but cannot get service...anyone??
Old Sep 1, 2010 | 11:28 PM
fotodad's Avatar
How do you tune to channel 0? On my 08 I can only get channel 1 and an emergency channel somewhere in the 400s. I have tried everything to get channel 0... can't figure it out. Can't find the XM tuner in the trunk either.
H E L P !
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
stratous01
Oct 7, 2015 10:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
