Adding alarm components (shock, tilt, proximity)
Old Apr 3, 2009 | 02:39 PM
ketchupfreak's Avatar
First of all, does our factory alarm even have a shock sensor? Has anyone successfully integrated different sensors into the factory alarm? With the amount of theft and vandalizing around here, I would love to add some of these to deter or delay theft. Anyone?
Old Apr 4, 2009 | 02:04 AM
KulG35's Avatar
no shock sensor... my window was broken into and no alarm went off
Old Apr 4, 2009 | 09:14 AM
5u30five's Avatar
+1 on the need for shock sensors. i was looking around the previous gen forums and somebody did a DIY on installing one. i just dont know if it will work on second gen g.
Old Apr 4, 2009 | 09:57 AM
STCLAIRWEST's Avatar
Im sure you can add a shock sensor to make your oem alarm better.
Old Apr 4, 2009 | 06:39 PM
rustyeleio's Avatar
I have not seen anything for our years yet. Directed Electronics Inc. (DEI) has adaptors up to '06 but the '07+ comes up blank on their website. The unit is called Bypass Essentials Xpress Kit and allows you to integrate a Python alarm system (maybe other brands as well). I can't say what exactly it does and how it accomplishes it but it is supposed to plug right in to our harness. I guess you could contact them about an updated firmware possiblity in the future. Good luck.
http://www.crutchfield.com/p_607XK02...=detailed_info
http://www.directedstore.com/InterFace.asp
Old Apr 4, 2009 | 06:43 PM
Vrod-Mike's Avatar
I sell DEI products and none of those kits work. The link you provided is just the immobilizer bypass used when adding a remote starter. There is an alarm made by them that is made to work with the OEM remote, but it's not plug and play so unless you have experience I would say let your local shop do it.
Old Apr 4, 2009 | 06:44 PM
Vrod-Mike's Avatar
You can. Just add the sensor output to the hood switch input. It's pretty easy to do.
Old Apr 4, 2009 | 06:49 PM
rustyeleio's Avatar
Damn that Crutchfield! Thanks for the clarification.
Old Apr 5, 2009 | 02:46 AM
What about a proximity sensor? Would this be the correct part?
http://cgi.ebay.com/DEI-504M-OEM-INT...3%3A1|294%3A50
And
http://cgi.ebay.com/DEI-508D-Dual-Zo...3%3A1|294%3A50
Old Apr 5, 2009 | 08:16 AM
Vrod-Mike's Avatar
Originally Posted by ketchupfreak
The second one is what you want, but let me say I've installed hundreds of that exact unit and they are a bitch to adjust properly. Everything sets them off. The sensitivity also changes with temps so if you install it in the summer you'll most likely have to readjust it in the winter. I was never a fan of proximity sensors. Put a shock and glass sensor on your car and that will be good enough.
Most people think a proximity sensor will prevent people from touching their car when in reality it draws attention to their car. When the alarm chirps just when someone gets close enough to the car it makes people want to see how sensitive it is an they may spend more time near the car then if there was no sensor at all in it. There's no way to prevent someone from vadalizing or trying to break into your car. All an alarm is supposed to do is prevent someone from stealing your car and even that is most likely not going to happen if they really want your car.
Old Apr 5, 2009 | 08:58 AM
CarFreak's Avatar
I tired to locate the hood switch, but it is very different from the 07'+ sedans
Old Apr 5, 2009 | 04:13 PM
Thanks for the info. I guess I'll be adding a shock and glass sensor. Do you have a link for both parts?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
