Vehicle Alarm Impact Sensor ??
Old Dec 13, 2009 | 09:49 PM
IgorNYC's Avatar
I was looking into this, a friend of mine got his window broken in front of his house. And it didnt even make a noise.
They have this for the 09 G37's.
Is this possible for the 08 G35??
I couldn't find anything on this with an answer..
Thanks
Old Dec 14, 2009 | 03:16 AM
hybridamp's Avatar
I have also been curious if there was an oem solution for a vibration sensor...
Old Dec 15, 2009 | 04:18 PM
dohturdima's Avatar
Well, the part seems to be here: the only thing left is finding out whether it can be retrofitted to 07-09 models...
http://www.everythingnissanparts.com...99m2-vu003.htm
Old Dec 16, 2009 | 02:03 AM
hybridamp's Avatar
Nice find; that makes me even more interested.
Old Dec 16, 2009 | 06:04 AM
harp00n's Avatar
+1 subscribed
Old Apr 1, 2010 | 09:59 PM
hybridamp's Avatar
To answer your question hybridamp, yes, this works.
So, I figured I would take one for the team here and order the OEM sensor from that link posted above to see if it worked. The sensor arrived in a "kit" that included the sensor, wiring harness (with ground ring terminal), tie straps, posi-tap style wire taps, a small business card style owners guide, and installation instructions for what I think is the coupe.
Followed the instructions and several minutes later, voila, shock sensor working. I had to use a slightly different mounting location because the location that the instructions specified was blocked on my sedan, so I used an adjacent location.
Old Apr 2, 2010 | 02:44 AM
harp00n's Avatar
Hey, thank you very much for this information!
Old Apr 2, 2010 | 02:56 AM
TIAN's Avatar
Hold The Line
Link doesn't work
Old Apr 2, 2010 | 02:59 AM
hybridamp's Avatar
Hrm, maybe the site is down at the moment because I checked it when I made my last post and it was working then...
Old Apr 2, 2010 | 03:35 AM
TIAN's Avatar
Hold The Line
Up now
Old Apr 2, 2010 | 03:36 AM
TIAN's Avatar
Hold The Line
** Thats what she said** hahaha. Im wasted sorry
Old Apr 2, 2010 | 10:15 AM
dohturdima's Avatar
Thank you hybridamp for taking the plunge and congrats on a successfull install! Ordering it as well. Could you specify which "adjacent location" that you used during your install?
Old Apr 2, 2010 | 10:44 AM
hybridamp's Avatar
The instructions show it installing to a large factory wiring harness near the BCM using a tie strap, but I couldn't get mine located on the harness as indicated due to a "Y" split in that harness. Maybe my sedan has an extra harness or something? Anyhow, I had another large wiring harness near the one indicated that it would fit on so I used it instead.
If you're curious about wiring, you tap three wires at the BCM using the included posi-tap style wire taps and connect a ground wire using a bolt near the BCM.
Old Apr 2, 2010 | 02:02 PM
dohturdima's Avatar
Thank you, this helps a lot.
Old Apr 2, 2010 | 04:04 PM
hybridamp's Avatar
No problem, I wish I would have slowed down and taken some pics for you guys, but yesterday was the first nice day we've had in a while so I was working quickly to get it done and move on to more enjoyable activities.
