climate control problem + clock
Old May 8, 2011 | 10:26 PM
rangerlim's Avatar
so i always keep my AC on, and it would always stay on after i shut my car off and what not. but now after i power back on the climate Control is off and i have to manually turn it on again... i know it's not a big deal but i was wondering what's wrong; i did have the battery replaced. was wondering if there's a setting. i tried going the the diagnostic, but dont know whats going on there. and another note. my dashboard analog clock is not working either after the battery change, nor the the hands move after i depress the adjustment buttons...
anyone have these problems?
07 g35 sedan sport
Old May 9, 2011 | 12:39 PM
RemmyZero's Avatar
have you checked to see if you blew the clock fuse? or any other fuses which may pertain to the "memory" on these devices? most likely that's your issue.
let us know what you find!
- Bob
Old May 9, 2011 | 01:05 PM
kool_yaar's Avatar
^whs check fuse for clock and for the CC try pressing and holding the "recirculate" button for a few seconds until both lights start blinking and see if that helps cause with this step you can adjust if CC should be auto or not.
Old May 9, 2011 | 03:38 PM
rangerlim's Avatar
i have tried pressing the recirculate, and where would the fuses be for the clock? i check the fuse box next to the driver side.
Old May 12, 2011 | 01:16 PM
RemmyZero's Avatar
well it's in the driver side. you'll have to check the manual but there is likely a general fuse for the radio or climate control or something which powers multiple components.
Old Jun 18, 2011 | 10:21 AM
rangerlim's Avatar
Thumbs up
so after driving around without being able to figure it out, finally took it in the the dealer, they replaced the fuse i couldn't find... they fixed the analog clock/ and the ac memory, they also replaced my driver and passenger door slots, where from the wear and tear the black started cracking and what not.... thumbs up for them.... they had to order some window trim because the heat just wears it out... anyways didn't pay a cent, and washed my car.... got a loaner.. i love their service!! but just have to drive an hour to get there... but other than that their service is pretty good.
arora_g35
Apr 16, 2026 02:52 PM
derres
Aug 28, 2015 03:27 PM
erickLA
Aug 18, 2015 04:46 AM
Tyler's03G
Aug 13, 2015 10:04 AM
