OHMS LAW could be so confusing!
Old Jul 19, 2011 | 02:55 PM
pbabajan's Avatar
ok so i have an ALPINE MRP-M1000:
http://www.crutchfield.com/S-7bfidyL...MRP-M1000.html
i want to get a RE AUDIO SXX 12" but i am so confused on which one to get!?
http://www.sonicelectronix.com/item_...2-SXX12D4.html
http://www.sonicelectronix.com/item_...2-SXX12D2.html
would i need the 2ohm version or the 4 ohm to get the full 1000 watts out the amp? i thought i understood the ohms law at 1 point but then got completely lost somewhere along the way!
also if u have a better sub in mind to go along with my amp please do tell!
any help/opinions/comments much appreciated!
Old Jul 19, 2011 | 03:09 PM
faiz23's Avatar
Its pretty simple what to get. Alpine amp is not worth it but if you want that amp and it is best rated at 1000watts @ 2ohms. You can get the D4 version of the sub which is dual 4 ohm coils. You can wire up the sub as 2 ohm and run the amp bridged. The amp will see a 2ohm load from the speaker and run at 1000w. You can find better amps that can go stable to 1 ohm and buy the D2 version. The lower the OHM/ resistance the greater the wattage the amp will push out. To a certain extent since amp might not be stable at 2 ohm, 1 ohm or .5 ohm.
Old Jul 19, 2011 | 03:19 PM
pl_G35's Avatar
How many subs are you planning on running?
If one then get the 4 ohms....connect the two coils in parallel
if two then get the 2 ohms....connect the two coils in series and the subs in parallel
(image shows 4ohms coils, 4 ohms out....but if u use 2 ohms coils output will be 2 ohms)
Old Jul 19, 2011 | 07:20 PM
pbabajan's Avatar
i already have the amp so im just sticking with it, and im planning on running only 1 sub til later at least
brianuc4
19
Apr 10, 2020 02:12 PM
Rose M
Oct 12, 2015 10:00 AM
1Typhoon
Sep 25, 2015 08:45 PM
