Need help with Audiocontrol LC6i install Bose/no nav
Old Nov 29, 2013 | 04:34 PM
clamchauda931's Avatar
Talking Need help with Audiocontrol LC6i install Bose/no nav
So i need some help with this Lc6i, this bose amp is proving to be a problem.
I will be replacing the midrange and tweet in the front door and replacing my backdoor mids and powering them off of a PDX-F4
Midrange and tweet off of 1 and 2
rear mids off of 3 and 4
and using channel 3 on Lc6i for a sub line out
I plan on keeping the bose amp running for the center channel and door woofers.
So basically what i am asking is which wires do i need to run to the lc6i
sound signal Front LH and RH to channel 1 on the Lc6i for the most part i understand this fine.
but my main problem is listed below.
sound signal Rear door LH and RH AND sound signal rear LH RH to channel 2?
The woofer channel i understand
Thanks for reading guys and thanks for any input!!!
Old Dec 2, 2013 | 04:04 PM
2ndgen's Avatar
have you looked here yet?
https://g35driver.com/forums/v36-aud...g-diagram.html
Old Dec 11, 2013 | 01:44 PM
eventually got everything figured out, wayyy easier that i thought it was going to be
EnCr1pt3d
Jul 8, 2019 02:48 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Danielek
Sep 20, 2015 12:08 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
