Data Base: Lowered with Aftermarket Rims/Tires
Old Oct 8, 2010 | 10:37 AM
  #91
yaysarahzon's Avatar
Originally Posted by baileyt35
I've decided to go with 245/45/18 set up on all (4) corners. I've also decided to have the Eibach pro-kit installed with rear camber kit. You guys think I'll have any issues? Any thoughts would be greatly appreciated.
I have the same drop as you and I was wondering how your tires fit. What offsets are you running. I have work vs-xx 18x9 +38 offset all around. I need to see what tire set up I need to look clean
Old Dec 31, 2010 | 11:56 AM
  #92
westibbs's Avatar
I have a 2008 g35 Journey RWD. If i do a similar setup to h2mann with 245/35/19s front and 275/35/19s back on OEM 19 inch wheels from a 2005 coupe, would I absolutely have to do a drop to compensate for the slightly shorter overall diameter of the proposed setup over stock 225/55/17s up front? I've been doing research on wheel diameter calculators, and I'm short by one inch up front, which sends red flags to me. More so on looks than anything else.
Old Feb 28, 2011 | 11:05 PM
  #93
salvador312's Avatar
Just wanted to share my set-up, Dropped on Eibachs! Posting pics after wheel alignment!
Front: 245/35-19x8.5 +35 5mm spacer
Rear: 275/30-19x9.5 +45 5mm spacer
Old Mar 21, 2011 | 01:43 PM
  #94
GSoccer24's Avatar
I've been searching for a few days and haven't found the info. I've tried the calculators on 1010tires.com and wherever else as well but still can't make a determination on this so any help is welcome.
Will 18"x9" with a +30 offset and a 245 width tire work on the rear of a V36 sedan?
Thanks in advance.
Old Jul 3, 2011 | 11:43 PM
  #95
r.o.c.'s Avatar
would 20x11 +15 in rears fit on stock without any rubbing issues?
Old Aug 5, 2011 | 03:43 PM
  #96
ahrajani's Avatar
2008 G35 Journey - 20" Rims & Tires
My setup:
Model: 2008 G35 Journey
Suspension: (Stock except for Hotchkiss F/R Sway Bars)
Front Wheel Size: 20x8.5
Fr Offset (mm): 40
Front Tire Size: 245/35/ZR20
Rear Wheel Size: 20x9.5
Rear Offset (mm): 40
Rear Tire Size: 275/30/ZR20
Wheel Mfr: Enkei
Wheel Model: Performance Lusso
Tires: Hankook (Ventus V12 EVO K110).
Here are two pics, but you can see others in the full post here:
Old Aug 5, 2011 | 04:17 PM
  #97
Pic
Old Aug 7, 2011 | 01:09 AM
  #98
jasyn's Avatar
so are you running +40 +50 or are you running +35 and +45 but you originally bought them at +30 and +40 and had to run 5mm spacers?
Old Aug 7, 2011 | 01:15 AM
  #99
You gotta read about offsets a bit more! Wheels originally with +45 and +35 offsets! And with the 5mm spacers all around that puts them at +40 and +30! So with bigger spacers the offset number goes down! The less the number the more is gonna stick out! The bigger the number the more is gonna sink in!
Old Aug 7, 2011 | 01:27 PM
  #100
jasyn's Avatar
haha yes. u got me on that one my logic was incorrect so you are at +40 and +30 now. thanks.
Old Sep 25, 2011 | 10:40 PM
  #101
MistaGrims's Avatar
Originally Posted by The Punisher
The punisher
07 g35S
lowered with Eibach pro-kit
Vellano VST
22x9 Front 38offset 245/30r22 Falken FK452
22x10 Rear 48offset 255/30r22 Falken FK452
NO RUB
...Pictures available upon request
@ The Punisher - Can you send me a few pics of your wheels? I have an 07 G35 Journey Staggered 18" OEM, Eibach ProKit Springs, KYB Shocks. Im looking to get 20" wheels NON Staggered
Old Feb 10, 2012 | 09:16 PM
  #102
bat6wc's Avatar
AWD....Swift Springs, G37S 19x8.5 +43 around, Continental DWS 245/40/19 tires
Old Apr 8, 2012 | 01:47 PM
  #103
bsw845's Avatar
After buying the G35 in late 2007, I finally got bored of the stock look especially after years of seeing all the sick modded Gs here. And after month's of research and countless PM's to forum members, I settled on the following:
Coilovers: Tanabe Sustec Pro S-0C
Camber Kits: SPC Front and Rear
Tires: 245/35/20 f and 275/30/20 r
Wheels: Concept One CS10
-20x9 +36 f
-20x10.5 +45 r
Thanks to SoundMike for the countless PMs on offsets and widths. Also thanks to B2Autodesigns for the CO and Camber Kits. Finally thanks to Rusty at TNT Autobody and the rest of the TNT Autobody crew for helping me get the CO and Camber Kits installed. Anyone in Sac that needs install help go see these guys. I'll try to get some proper photo's together but for now some phone camera shots...
Old Apr 14, 2012 | 07:16 PM
  #104
blnewt's Avatar
-20x9 +36 f
-20x10.5 +45 r
Looking sharp, nice drop & wheels too
Old Apr 14, 2012 | 07:37 PM
  #105
blnewt's Avatar
Here's pics of my B&G S2 springs (w/ SPC F&R camber kits w/ toe bolts)
Drop is 25.75" to the bottom of front fender & 26.25 rear fender. Alignment in spec
These B&G springs are for 2007-2008 G35s (mine is a 2009 Journey), the drop is a bit more in the front for the 09+ since the 7AT adds 150 pounds. These on a G35 would be about 1/4-1/2" higher in front.
