What Springs To Get? Which One Is The Best?
Old Jun 19, 2007 | 09:17 AM
G35 S's Avatar
I was looking around and i see people with eibach springs and H&R springs but which one is better?
How should we work on the alignment after we install the springs?
Old Jun 19, 2007 | 09:22 AM
Altersys's Avatar
you might want to define what "better" would mean to you. when it comes to aftermarket mods, generally the question to answer is what do YOU want?
Old Jun 19, 2007 | 09:29 AM
G35 S's Avatar
I was looking for something that would be more fit for driving on a regular basis and driving it hard when i want it to. It looks x1000 hotter when its dropped.
Old Jun 19, 2007 | 09:32 AM
Altersys's Avatar
do you intend to also do new shocks? the more aggressive the drop, the more important it is to do new shocks.
this is particularly relevant on this car, as I find the damping rates on the stock shocks are a little low even for the stock springs.
someone with FHE can talk to which is more aggressivem H&R or Eibach. I have no idea (i'm running stock springs).
Old Jun 19, 2007 | 09:51 AM
G35 S's Avatar
I heard HR and Eibachs are about the same drop and they are perfect fit for it and they run real good. Do you know anything about after installing the springs that we have to get alignments and other crap done?
Old Jun 19, 2007 | 10:07 AM
Gcrazy08's Avatar
You usually always need to get an alignment done after altering a cars suspension...it may not feel like you need one but you will eventually see uneven wear on your tires or a slight pull of the steering wheel here and there. An alignment is usually not that expensive and will cure all those things after lowering a car. You should usually wait about 7-10 days so that the springs settle before aligning.
Old Jun 19, 2007 | 10:18 AM
G35 S's Avatar
How often should you get a alignment after lowering the car?
Old Jun 19, 2007 | 10:34 AM
Gcrazy08's Avatar
you should get it done 7-10 days after you install the new suspension and you should be fine but if you start to see uneven wear on the tires or feel the wheel pulling then you can have it re-aligned when needed. You'll know if your car is out of alignment. its kinda noticeable
Old Jun 19, 2007 | 10:43 AM
G35 S's Avatar
Is there anything else we should do after we get new springs?
New shocks?
Old Jun 19, 2007 | 03:36 PM
Gcrazy08's Avatar
It seems to me that mostly everyone that has lowered their cars on this forum has kept the factory shocks and struts in and just added the lowering springs. I think eventually the shocks and struts will need replacing after a while but its not a nessecity to replace them right away.
Old Jun 19, 2007 | 03:52 PM
Altersys's Avatar
it's not about blowing the shocks. if you want your car to ride well with higher-rate springs, you have to run higher damping rates, or you will get oscillation.
those ghetto rigs you see on the freeways bouncing around like it's the business? yep, cut springs and stock shocks. worse handling than stock....
Old Jun 19, 2007 | 10:33 PM
G35 S's Avatar
How should i set up my springs and everything if i want to lower my caR?
Old Jun 19, 2007 | 10:46 PM
terrycs's Avatar
I'd say there is enough experience with Eibach and H&R in this forum to recommend them for use on the S. Each owner that has lowered their car with springs from either mfr will have their reasons for making their selection.
Some folks are still on the wall about camber correction kits for the car, but IMHO, at the very least, consider a camber correction kit for the rear. You will find the camber can no longer be adjusted back to factory specs.
Old Jun 22, 2007 | 08:03 PM
John2.5RS's Avatar
the fronts may not be able to get back into spec either, I know Mine couldn't get into spec, but the tires don't appear to be wearing to uneven yet.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
