Would these wheels fit on my 07 g35x?
Old Jul 23, 2007 | 06:31 PM
Pdubz's Avatar
would these g35 coupe 19'' staggered wheels fit on my 2007 g35x?.. i heard someone say putting stagged on my g is bad.. is that true?? i really want to purchase this but i need to kno if its gonna mess up my ride
Old Jul 23, 2007 | 09:11 PM
Christian's Avatar
It is strongly recommended that you do not put a staggered setup on the X because it is said to be harmful to the AWD system. I like the 19" coupe wheels too, so I'm a little disappointed that I can't use them on my G.
Old Jul 24, 2007 | 02:56 AM
DannyDeez's Avatar
If two people bought sets of the coupe rims then you could each swap 2. This way someone would run 4 "front" rims and the other would have 4 "rear" rims.
Old Jul 30, 2007 | 02:17 PM
FutureGDriver's Avatar
u can go staggered but u just have to pull the awd fuse, many people here have done it,
Old Jul 30, 2007 | 02:48 PM
brown_fv's Avatar
i know quite a few of people on the FX forum that run staggered set ups on their AWD and they have no issues.
if the AWD system is the same it should no be a problem.
Old Jul 30, 2007 | 03:00 PM
JessterCPA's Avatar
It's not the stagger that's the issue. It's the fact that on a AWD system, the front & rear tires (or left to right for that matter also) have to be the same height. That gives the same circumference.
I remember on my Subaru, if I needed to run the spare tire (which was not the same circumference) you would hear the differentials working overtime even as you drove in a straight line.
If you could somehow get staggered tires with the exact same circumference, I would then see no reason why you could not do it.
Am I wrong?
Jesse
Cajuncowboy
Jun 21, 2021 09:47 AM
reavensf
Sep 17, 2015 11:30 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EasySausage
Jul 20, 2015 03:56 PM
