People with 19" and 20" Aftermarket Wheels
I was hoping for some help...
I wanted to ask those of you who have bigger wheels/tires if there are rubbing issues. I have a black 07 G with the stock 18"ers and wanted to get the EXE Konclave wheels in either 19" or 20" .
If I go with 19" EXE Konclaves, do I get 9.5 rear and 8.5 front? And which offset? Do I need specials springs or does 19" fit flawlessly on the G sedan.
Also, how do bigger wheels change the gas mileage of the car? Good, bad, the same? Do any of you think it gives you better MPG?
Thanks
Thanks
check out the word doc located here...
https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/159247-data-base-lowered-aftermarket-rims-tires.html
or you can go through each page of this thread
https://g35driver.com/forums/media-share-v36-sedan-245/
Thanks
Thanks
Originally Posted by TheIvoryG
This may be a stupid question...so my apologies...but I know that the gas mileage will be worse. But will the actual tracking of miles ticking away also be affected?
The key here is not to install a larger wheel and tire combo to get to a larger overall rolling diameter. Were are not trying to build a monster truck, by install larger tires. We are increasing the size of the wheel and decreasing the sidewall of the tire ultimately keep the exact same diameter around the tire tread. 24's will not rub if you can find a tire with short enough aspect ratio i.e. 245/10/24
24's won't rub unless they are too wide or you put too tall of a tire on it.
Originally Posted by ommmjido
wether or not u'll rub depends on the combination of width, offset and tire size, not the wheel's diameter. u can put 22"s on and not rub but u can also have 17"s that rub. it also depends on ur suspension setup.
There are many web resources. Do a bit of research before buying and you should be fine.
So if I were to get 19" or 20" wheels, which offset and width should I go with to ensure it won't have issues with stock suspension.
Is it safe to assume that the stock 18" wheels' offset and width will be ok with 19" and 20" wheels too?
THanks
PS I have the 07 G35 S so I assume I can go wider in the rear, which I think I'll do.
THanks
No rubbing issues here. 19.9 MPG
Thanks
Thanks
THanks
THanks
You can match the offset from the sport 18" wheels but only if you use the same width wheels - 7.5" and 8.5". 8.5" and 9.5" will require different offsets.
The Journey and the Sports can run identical offsets as I understand it. The 18 inch sport wheels are available on the journey as an upgrade, so I believe they are identical.
i've been looking at wheels, and i looked at the wheel and suspension guide, but a lot of pictures don't show a perfect shot from the back side to see how much the wheel stick out. I want a wheel that either sit flush or sink in a bit, and i want to go 20x8.5 front and 20x10 rear, what offset will be best for me?
Thanks guys. It would help me tremendously if someone could tell me what offset to get if I want to get 8.5 up front, 9.5 in the rear with 19" wheels.
Also, based on the offsets you guys recommend, what is the WIDEST I can go with tires? I have some tires that are 19/30/265 rear and 19/35/235 front and I'd like to use them.
Thanks, this will really help me and two friends who want this answered as well.
