Rotating tires on a G with performance package
Old Feb 23, 2008 | 03:08 PM
Eclipse2G35's Avatar
Is it possible? I was at the dealer for oil change and I have just reached 7500 miles. The guy asked me if I want the tires rotated and I told him I have the performance package. He said they still can do it. I just told him no thinking he was just trying to sell stuff I don't need.
Old Feb 23, 2008 | 03:10 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Its 8 front and 8.5 rear, so no.
You would have to un-mount the tires and re-mount them to rotate them.
do you have the 18's or 19's??
I also belive the 18's are staggered, but I know for a fact the 19's are..
Old Feb 23, 2008 | 03:16 PM
I believe the sedan only has the option of 18s. Here is what it says from the Infiniti website:
Performance Tire and Wheel Package
* - G35 Journey: Split 7-spoke 18 x 7.5-inch (front), 18 x 8.5-inch (rear) aluminum-alloy wheels. 225/50R18 (front), 245/45R18 (rear) W-rated summer performance tires
I believe he said he would unmount them and mount them back. Even then, how would the tires fit when they are different sizes?
Old Feb 23, 2008 | 03:34 PM
TURBOTOM's Avatar
a.k.a kleicoupe
It would work, but you can only go front-to-front, and back-to-back.
I need to do this to my front tires soon because of the tire feathering.
Old Feb 23, 2008 | 07:00 PM
blnewt's Avatar
The tires don't need to be unmounted, but you can only switch form side to side, it should help lengthen the life a bit, but not as much as a full four tire rotation would. If you'll notice the Potenzas have OUTSIDE printed on the tires, so as long as you keep the Outside to the Outside you'll be fine, but since the tires & wheels are different sizes you can only go side to side
Old Feb 23, 2008 | 08:49 PM
JMZ_blkobsidian's Avatar
Uh, I thought no...
the wheels are staggered, and I thought the tires are directional. So you couldn't even do side-to-side.
Old Feb 23, 2008 | 10:44 PM
TheIvoryG's Avatar
I don't know what the stock tires are, but staggered and directional can have limited rotation. You have to unmount the tires then mount and balance them on the other side of the car. Obviously not front to back.
Old Feb 24, 2008 | 11:24 AM
dopey's Avatar
Take a look at your tire. Unless you don't have the RE050As.
Here's the tirerack photo:
http://www.tirerack.com/tires/BigPic...Potenza+RE050A
Note there's no directional arrow indicating a directional tire. There is the nice little "outside" printed on it though, so you can swap side to side.
Old Feb 24, 2008 | 11:43 AM
blnewt's Avatar
X2
Folks confuse directional w/ outside bias tires, big difference. ALL directional tires have an arrow in the direction of forward travel, outside bias tires have Outside only printed on the side that needs to be mounted to the outside of the wheel, and these outside bias tires CAN be switched to the other side. Obviously the staggered wheel sizes limit the backs to the backs and the front to the fronts, but they CAN be partially rotated.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Fireman07603
Aug 9, 2015 06:00 PM
Siciliang35
Jul 25, 2015 02:49 PM
