Tire question for 07 G Sedan Sport?
Old Jul 16, 2008 | 11:40 PM
G35_Trinh's Avatar
I was woundering if anyone tryed to put the same size tire or the rear to the fronts. If you guys did, did feel any different at all and how dose it look with it on?
Old Jul 17, 2008 | 09:02 AM
snowcrossmxz's Avatar
yes i do it for my winter tires 245/45/18 on the front of the sport works fine. zero issues
Old Jul 17, 2008 | 10:09 AM
Scooby24's Avatar
It shouldn't be a problem for speedo since the speed sensor is either in the tranny or the diff.
But the same size tires on an inch narrower wheel will look a bit more bloated and tall.
Old Jul 17, 2008 | 10:10 AM
sredish's Avatar
you could run 245/40s on all 4.
Old Jul 17, 2008 | 10:51 AM
check out this thread.
https://g35driver.com/forums/showthr...ghlight=muffin
Old Jul 17, 2008 | 12:45 PM
hrp783's Avatar
how about making the front 235 and the rears 255??
on stock sport wheels
Old Jul 17, 2008 | 12:49 PM
sredish's Avatar
i have 245 fronts and 275 rears, the 235/355 scenario wouldn't be a problem but it sounded to me like he was wanting all 4 to be the same.... I wouldn't go wider in the front than the rear, but the sport rears are 245/45/18 and you could fit those on the front except the sport front wheel is 7.5" wide and I think you need an 8" or wider to fit the 245's.
Old Jul 17, 2008 | 01:00 PM
hrp783's Avatar
you can go that wide on the stock wheels with out rubbing??
Old Jul 17, 2008 | 01:29 PM
sredish's Avatar
no, I'm running aftmkt wheels, but I was just making the point that there's room up front for 245/45s, which is what the rear size is, the limit is the wheel width. But, I don't think I'd run anything narrower than a 245 in the rear so that kind of limits what you can do. Not that I'm recommending it, but you could probably run a 245/45 on the front of a stock 8" sport wheel, it just might wear a tad bit quicker due to it rolling the sides a slight bit more than the recommended 8.5" wheel.
- 19" Axis Decades/Kumho SPTs -
Old Jul 17, 2008 | 04:52 PM
Phalanx's Avatar
What is the widest size we can put on stock sport wheels? I would like to know that information.
Old Jul 17, 2008 | 04:59 PM
sredish's Avatar
Pretty limited on an 8.5" wheel. 255/40/18 is probably all your gonna get.
Old Jul 17, 2008 | 09:29 PM
Phalanx's Avatar
How about the front wheel?
Old Jul 17, 2008 | 09:34 PM
GEE35FX's Avatar
The front wheel on the sport is 7.5" wide. A 245/45/18 would be the max you could put on the front rim, you would not want to go any wider.
I have run 255s all around but that was with 8.5" rims.
Old Jul 17, 2008 | 09:37 PM
sredish's Avatar
so you ran 255s on the front? what was the aspect, 40s? And this is on an 18" wheel I'm assuming.
Old Jul 17, 2008 | 09:41 PM
GEE35FX's Avatar
Yes I ran 255/40/18 Michelin PS2 all around on my 8.5" x 18 PIAA rims. They were a bit small on the outside diameter though, but I never had any issues other than my speedo being out a bit.
