Wheel and tire size help please
Old Jul 24, 2008 | 11:38 PM
ketchupfreak's Avatar
I am dropping my sedan on Eibach Prokits and I am wondering which offsets and tires sizes I will need to not rub.
The wheels im looking at are Axis SuperHiro's in 19" 8.5 front and 9.5 rear.
First, what offset should I be running?
Second, these are the tire package sizes listed on a major website,
Staggered Tire Option 1 :
Front: 245/35R19 Rear:285/35R19
Staggered Tire Option 2 :
Front: 245/35R19 Rear:275/35R19
Staggered Tire Option 3 :
Front: 255/30R19 Rear:285/30R19
Any help is greatly appreciated. I am driving the car more for comfort and not stance. I dont want to rub or scrape through driveways.
Thanks!
Old Jul 25, 2008 | 05:06 AM
heyitsalex's Avatar
offsets:
FRONT: +25 - +35 (aggressive - conservatve)
REAR: +35 - +45 (aggressive - conservative)
Tires:
FRONT: 245/35/19 (245/40/19 is the proper tire size to keep with OEM specs but looks real funny on an 8.5 wide wheel. too much rubber)
REAR: 275/35/19 (proper size to keep with OEM specs but look like too much rubber depending on brand of tire. I would suggest a 10in rear wheel)
Old Jul 25, 2008 | 09:48 AM
snowcrossmxz's Avatar
Originally Posted by heyitsalex
offsets:
Tires:
first off, alex is a good name.
second,, what do you mean when you say too much rubber, do you mean it won't look stretched, but the oposit. or do you mean the sidewall ratio is too high?
Old Jul 25, 2008 | 11:33 PM
heyitsalex's Avatar
The tire wall is too thick. The sidewall ratio is too high.
I'm assuming your name is Alex too, or are you just trying to hit on me?
Old Jul 26, 2008 | 12:08 AM
AlterZgo's Avatar
Go with 245-40-19 up front. It'll look fine. Check out all the people w/ M45 rims. They're all running 245-40-19s. This will:
1. Match stock diameter so your speedo and odo will not be off.
2. Provide more rim protection.
3. Give a better ride.
4. Provide slightly more ground clearance.
5. Keep the front wheel well gap from looking way too big. As it stands, the front wheel well opening is cut larger than the rears. If you ran 245-35-19s, the front wheel well gap just looks way too big.
IMO, of course.
Old Jul 26, 2008 | 08:21 AM
mishmosh's Avatar
LOL!
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
Popes
Jul 29, 2015 05:07 PM
Detailed Image
Jul 24, 2015 12:31 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
