20" wheels in rear and 19"s in front? Anyone??
anyone have 20s in the rear and 19s in front? My friend from ronjon wheels is hooking me up with a set of his 3 piece wheels and and gave me the idea of running this setup bc i did it on my lexus.
anyone have this setup or similar and pics??
thanks
thanks
Here you go:
https://g35driver.com/forums/picture...new-shots.html
I think he's the only sedan running 19/20
Originally Posted by Omegamerc
Wouldn't that mess with your AWD?
heres the wheels he made, also comes in a black with chrome lip
Im running 20s in rear and 19's up front. Still on stock springs
http://s117.photobucket.com/albums/o...ent=carbro.jpg
Originally Posted by beezy619
Here you go:
no they are both 20s
i know him
Originally Posted by sredish
tire width, wheel size, none of that matters, just overall diameter. you could have a 16" in front and a 22" in back as long as the overall tire diameter matches.
Don't do the 19/20 F/R thing. It just doesn't look good because the front wheel well on a G35 is cut higher than the rear so running 19s up front would just make the front wheel well gap appear larger since you'll have to run a taller profile tire up front.
IMO, staggered only looks good on sports cars (NSX, Corvette, Lambo, etc.) where the front end is noticeably lower than the rear. On a 4 door sedan - or even on a G37 coupe where the front end is pretty thick and beefy, it looks like crap.
Additonally, I like the ronjon rims alot. However, note that these rims are made specifically for hondas and acuras. While the 5x114.3 bolt pattern will work on our cars, the center bore for the hub on Hondas are 64.1 mm whereas Nissans are 66.1. This means the rims won't fit on your car unless you get an adapter to convert your G35's centerbore from 66.1 to 64.1. Since you need to go to a smaller centerbore, you can't just put in a center bore ring. You will need to install an adapter/spacer. This isn't all that bad because the ronjon rim offsets are pretty conservative and you'd want to run a 10mm to 20mm spacer on them anyway depending on whether you buy the +40 or +52 offset rim.
The only reason i am going with those wheels is bc he has a pair of brand new 20s already with tires on it from a photoshoot, i didnt want to go with 20s but since im good friends with him hes giving them to me at cost. well see if i want to splurge the extra money for 20s in front too...but I do know what you mean on the front esp on the X. i hope they come out with springs or coils soon for my car.......the 20's do come with a 3" lip though!
I checked some more and I've seen people mention Infiniti center bores are 66.06, 66.1, and 66.2 - which are all essentially the same. I haven't seen anywhere mention it to be 67.1.
FWIW, I just installed 20mm spacers on my 08 G35 sedan yesterday and they were hubcentric w/ 66.1 center bore. The spacers and M45 rims fit the car perfectly. So, I'm pretty sure it's 66.1.
Even if you do get them bored out to the correct Infiniti center bore, I still recommend spacers to push the rims out for a nice flush look.
Spacers aren't necessary with M45 rims. I ran them w/o spacers for about 10 months. I ended up putting 20mm spacers on all 4 corners because I will be lowering my car this week. It just looks much better w/ spacers - especially when the car is lowered - because the rims camber inwards and tucks in pretty far when lowered. Here's a pic of jayjay's G without spacers - note how tucked in the wheel looks?
If you're not lowering the car, 15mm spacers all around would look good.
I went w/ some ebay spacers for about $75/pair. They seem to be pretty good quality - machined alum/mag alloy, are hubcentric, and seem to fit perfectly. After I put them on, I test drove my car up to about 90 mph and no vibrations or issues at all.
http://cgi.ebay.com/ebaymotors/20MM-...spagenameZWDVW
rezendvous420
May 31, 2020 01:26 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
