M45 Wheels Spacers? Longer Studs?
Old Feb 23, 2009 | 12:00 PM
4 Door Skyline's Avatar
Question M45 Wheels Spacers? Longer Studs?
Sorry if this has been answered before, dont flame please and yes I used the search button....Im no newb
Is it absolutely necessary to use spacers and/or longer studs to use the m45 sport wheels on an 07/08? My car is a lease and pretty much all I want to do is bolt ons and no permanent mods. TIA
Old Feb 23, 2009 | 12:08 PM
bert039's Avatar
I'm not sure on the 07/08's, BUT you can get spacers with longer studs built in, like Project Kics, and they'll be bolt on's that you can do by yourself without any special tools.
Old Feb 23, 2009 | 12:12 PM
Kinn's Avatar
i researched this several times, and from what i've found, no spacers are needed for the 07+ G sedans. In the 2nd link, towards the middle, there is an IP sedan with the M Rims with no spacers. He said it looks and ran fine! Good luck!
https://g35driver.com/forums/g35-sed...port-rims.html
https://g35driver.com/forums/picture...oofyg28-5.html
Old Feb 23, 2009 | 12:13 PM
Sounds interesting, thanks....lets wait to see if others chime in on the absolute necessity of studs/spacers
Old Feb 23, 2009 | 12:23 PM
CalsonicVQ's Avatar
The wheels will bolt on just fine without spacers. However, you may want to use spacers for aesthethic reasons.
Old Feb 23, 2009 | 12:52 PM
Sweet....sounds good to me....gonna go check out the project kics...Thanks guys
Old Feb 23, 2009 | 02:44 PM
mishmosh's Avatar
Yup. They are just fine...no rubbing issues.
So get 'em. And if you don't like the way they sit, you can get spacers later.
Old Feb 23, 2009 | 02:47 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^+1
& If you decide on spacers,
JMO, but I'd look for Hubcentric spacers, like Ichiba V2 instead of the Kicks
Old Feb 23, 2009 | 03:04 PM
Let me ask you something, Ive never dealt with or even seen any spacers on a car.....do these just lay against the hub and the factory studs go through? or do the factory studs have to be pressed out? And what size spacer do you recommend?
Old Feb 23, 2009 | 04:29 PM
InTgr8r's Avatar
There are several differnt styles.
Some are just plates & require new (longer) studs; they usually come c/with.
The other type have studs built in.
With these you bolt them on the the hub then the wheel uses the new stud.
With these there needs to be a pocket in the wheel for the old stud to go into. (between the holes)
...like these.
Old Feb 23, 2009 | 04:57 PM
So on the M45 wheels, is there that pocket? It doesnt seem like it to me
Old Feb 23, 2009 | 04:59 PM
G35Papa's Avatar
I think the smallest spacer you can get with built in studs is 15mm. I could be wrong though
G35Papa's Avatar
Yes, they have the "pocket" so the OEM stud will sit inside the hub of the wheel.
Old Feb 23, 2009 | 05:00 PM
CalsonicVQ's Avatar
Yes, the pockets are there. I am current using 20mm (F) and 25mm (R) spacers with the built-in studs with my M rims.
Old Feb 23, 2009 | 05:05 PM
InTgr8r's Avatar
Yup. That's the smallest I've seen too.
Basically you need enough meat there to support the new stud.
