SPC front camber kit arrived today
Old Mar 29, 2009 | 05:45 PM
E-Ticket Ride's Avatar
I was thinking that the guys experiencing the problems may be extremely lowered, to the point where they have very little available suspension arm travel.
I doubt I need the front kit anyway. Well, I'm hoping that I don't hehe.
Old Mar 30, 2009 | 12:13 AM
terrycs's Avatar
No rattling on mine. Everything working fine so far. I put in zero castor and eyeballed roughly halfway on the camber adjustment before I installed the UCA's. I got the car aligned and everything was good except for the toe! Amazing luck!
A tip I learned ... once you get everything back together, camber adjustments can be done, but not easily. The arm does not come down far enough to get a torque wrench on the camber adjust nut. You have to disconnect the swaybar again which will allow the UCA's to come down more.
Old Apr 1, 2009 | 02:34 PM
kmuniz78's Avatar
Can you take a pic of your front wheels head on; from the front of the car. I want to see how flush they are with the wheel wells. I do not have the kit. However, I am planning on getting this soon. The fronts of mine have negative camber, which is annoying me to look at. I like it flush!
Old Apr 1, 2009 | 02:43 PM
Cabad85's Avatar
i removed the front wheels today and checked in the fenderwells, there were no tell-tale signs of the arm hitting/tapping inside the fenderwell like what was shown on myg37.com. we have terrible roads here in the hampton roads area of virginia, when i hit pretty steep bumps the most i hear are hitting the bump stops maybe. i can't tell for sure, but its a pretty loud thud in the cabin. but lifting the car up and checking everything, i have not discovered any sort of damage except of course scrape marks on the plastic undertray of the engine. imho, there shouldn't be a problem with the sedans. i think if the drop was very aggresive, then there might be clearance issues between the fenderwell and the spc upper a-arms.
Old Apr 1, 2009 | 04:34 PM
mishmosh's Avatar
A little off-axis but you can tell that the camber is not off (-0.4*).
Old Apr 1, 2009 | 05:52 PM
kmuniz78's Avatar
mish - Just what I was hoping for. Many thanks!
Old Apr 10, 2009 | 09:31 AM
kmuniz78's Avatar
What is the part numbers for the front and rear SPC full kit? Also, are you guys ordering these kits through THMotorsports or SPC directly? Need to buy a kit today.
Old Apr 10, 2009 | 01:23 PM
kmuniz78's Avatar
NM, just ordered full kit!
Old Apr 10, 2009 | 01:25 PM
mishmosh's Avatar
The fronts are 72130..not sure what the rears are but I believe rears are from the previous gen. I think HP AUTO has good deals on them, especially if you have ordered from them in the past. Just pm Andy from HP AUTO.
Old Apr 10, 2009 | 01:29 PM
kmuniz78's Avatar
Just ordered through THMotorsports for the full kit (i.e. Front L/R upper control arms, and Rear L/R Camber Arms and toe bolt); $575 shipped. Should be here next week sometime.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
